Old 9th September 2002, 01:15 AM   #1
Default Blue LED for BOSOZ, how to implement?
I am just about finished with my BOSOZ but I would like to have a blue LED on the front panel.
Should I take a feed off of the power supply rails to the LED? If so should I use a resistor in front of the LED?
Thanks for any info.
Y.
Old 9th September 2002, 02:02 AM   #2
fcel is offline fcel  United States
Those blue led gets very bright. I suggest to start with a 200K resistor in front of the led. I remember someone on this forum install two leds - one on each rail - just so that it "looks balanced electrically".
Old 9th September 2002, 02:11 AM   #3
fcel, thanks for replying. Do I connect the LED directly to the power supply rail?
Thanks.
Y.
Old 9th September 2002, 02:36 AM   #4
Warp Engineer
On Holiday
AudioFreak's Avatar
If you want it to be balanced electrically, connect it across the +ve and -ve rails (instead of +ve to gnd) and double the resistance.
Old 9th September 2002, 02:40 AM   #5
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
If you want to do it really well , put some extra turns of thin wire on your toroid and conect LED there with a small resistor.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 9th September 2002, 04:30 AM   #6
Account Disabled
Waoowww...!
It's a fantasitc idea. Clap! Clap! Clap!
JH
Old 9th September 2002, 05:35 AM   #7
Account Disabled
Yochim
I like the way as in the figure.
You could install LEDs of as many as number of diode bridges.
You could make them by easy p2p wiring.
JH
Old 9th September 2002, 08:17 AM   #8
skaara is offline skaara  Slovenia
You dont even need a bridge for led
Old 9th September 2002, 09:08 AM   #9
You may protect the led with 4 1n4004 series across its pins.
This metod limits the voltage at 2.5 volts or so.
Old 9th September 2002, 09:42 AM   #10
But diodes will get hot, especially at that voltage?!
How should I implement these... flaevor Subwoofers 11 16th October 2010 08:35 PM
NFB, how to implement here? disco Tubes / Valves 0 12th August 2009 09:06 PM
Y B Blue - how blue LED improves the CD playback Peter Daniel Digital Source 176 25th September 2003 07:40 AM
Blue BOSOZ Roberto Amato Pass Labs 37 26th September 2002 12:48 PM
Page generated in 0.09368 seconds (77.72% PHP - 22.28% MySQL) with 11 queries
