Old 26th May 2005, 10:05 PM   #1
Buhl is offline Buhl  Denmark
Buhl's Avatar
Default A30 hardware
We all love hardware......at least I do - this is some of the goodies that I have found 2.hand for use in my upcoming A30....
Trafo: 2x25 volts, 800 VA - can be wired to 2x23 - and will lose about 4 volts in 1ohm / 50 watt powerresistors
Heatsinks: big, unused, got the for free from a friend whos company didnt need them in production (Thnx Peter !)
What do you guess I could sink with one of those - 100 watt ?
"Calculations? We don't need no stinkin calculations! We just make them really big!" Quote: Nelson Pass
Old 26th May 2005, 10:06 PM   #2
Buhl's Avatar
Heatsink from the top......
Old 26th May 2005, 10:07 PM   #3
Buhl's Avatar
Heatsink from the side.....
Old 7th June 2005, 08:35 AM   #4
Stabist is offline Stabist  Slovenia
Stabist's Avatar
Those heatsinks remind me to Classe amps ...
I doubt 1 peace is enough for 100W - if cutted on half - then you will easilly dissipate 100W on that new pair ...
Old 7th June 2005, 09:15 AM   #5
steenoe is offline steenoe  Denmark
steenoe's Avatar
Nice heatsink Fat bodyplate, very nice.
If you have 4 of those, you can make a monster amp chassis
Did you consider a Aleph 5, with those 25V secondaries?
Steen.
Old 7th June 2005, 09:31 AM   #6
Buhl's Avatar
Cutting the heatsing in half ? - so I have to halves, that makes double width, but half the higth ? - The area will be the same, ABOUT 4600cm2 each - so I dont see how cutting them could make them better ?
Steen - I first got the PC board for A30, then ran across the trafo - I know its to large, so mabye ill get a 2x20 volt, but this was very cheap, and since I would like to burn a couple of volts in an CRC (got some nifty power resistors for mounting on heat sink...)
But, the original A5 used 3 transistors pr. side, just like the A30, sure it should be able to handle 27-28 volts instead of 25 ?? I plan to lose 4 volts in the supply resistor.....
I have 6 of the heatsinks, and mabye 4 more, if I pursuade my friend that he'll never get to use his, and I should build him a GC instead ;-)
But I also have 4 pcs. of Zen 4 channels lying, along with two puwersupplys, so a balanced Z4 should also be build....
And then theres the pearl phono that Im struggeling with - it has some hum when turned up, mabye some grounding problem....
Cheers !
Hans
Old 7th June 2005, 10:23 AM   #7
Stabist's Avatar
Buhl - believe me - just check the K/W curve in datasheets for heatsinks - after some height - for an average heatsink at arround 150mm - the curve becomes very flat - eg - a popular Fisher SK56 - at 100mm height - K/W is around 0,40, at 150 arround 0,32 and at 200mm 0,29
So cutting one SK56/200 into 2 100mm ones - you have 0,28K/W vs 0,4K/W//2-->0,2K/W ...
Is there really no difference??
Old 7th June 2005, 11:29 AM   #8
steenoe's Avatar
You might be able to tweak the A30 PCB's into an Aleph 5, If you wanted to, that is
Stabist is right about the dissipation,IMO. But what a shame to cut those nice big heatsinks in half.
Did you make a GND connection to the PU arm, on your Pearl?
Steen.
Old 23rd February 2010, 06:55 PM   #9
Buhl's Avatar
Oh my god - time flies....4½ years since I started on this A30 project....it is almost to embarrising....
Chose to follow your advice Stabist, and cut the sinks - had it done at a local machineshop that also cut the 4mm panels - they did not do a very good job on the sinks - however, each sink has a nice looking side that I can use as top side Even though they also managed to scratch the "nice" looking side
Attached a couple of pics fra about 3 weeks ago - right now the case is painted, circuits mounted, and I am in the process of wireing it up...more to come....
/Buhl
Old 7th December 2010, 02:04 PM   #10
Buhl's Avatar
Damn.....almost a year more went by.....Got my self into a lot of trouble - got almost everything wired up when I discovered that my transformers (4x150VA EI Cores) buzzed like a jigsawe at full rpm. Tried rubber insulation - did'nt work - tried more rubber insulation - did'nt work. Builded a mains filter from scratch - did'nt work - cut all wires in anger and threw the EI's to h... - found a large 750 Toroid from a local manufacturer, installed it, wired everything up (I know - test before you do this) - and it blew all fuses that I had - bought a finished soft start module (The biggest DIY sin...?) - it still blew fuses - found out I had the secondaries wired up wrong (I did not have make that mistake on the EI's - they provided the correct voltage )
So - ten months and a lot of cursing and frustration later....It is beginning to look like something.....
Finishing hardware loninappleton Full Range 20 30th October 2008 08:34 PM
CNC cut MDF service or hardware? Daveis Multi-Way 14 22nd June 2007 10:11 PM
DIY hardware polkymon Multi-Way 2 5th March 2007 01:01 AM
Hardware?? lpd Tubes / Valves 5 6th March 2005 03:36 PM
Page generated in 0.10377 seconds (85.20% PHP - 14.80% MySQL) with 11 queries
