#21 |
well, i dug up 16 MUR1520's.
i desoldered the 1N4005's, and sure enough, half were 0 resistance on one board. so, they were shorting out the circuit. im going to replace all of them with the MUR1520's and hopefully that will work! i already tested all the MUR's and they all work ok with the diode tester, so they should be ok. i have to repair the traces though too , but that wont be too hard.
#22 |
sigh.
i replaced all the 1N4005's with MUR1520's and still the same problem. however, thanks to the light bulb suggestion, no more destroyed boards and diodes. i have all the secondaries and primaries from the transformer routing through a euro style connecting block. i have triple-checked it, and it doesnt seem to be the problem. when i take the PSU boards away and just hook up the transformer (with the connecting block), everything works fine and i get the voltages i should be getting. i turn it on, get the right voltage, the LED lights up on the connecting block, and the light bulb is off. as soon as i wire in the PSU board (just one of them), i turn it on, and a get a nice bright light bulb. very sad. i have tested all the resistors and diodes in circuit, and all seem to be ok. i dont really have a way to test the transistors, could they be causing a short? i also tested the caps, and they test great too. any ideas? i even used nylon parts to mount the board in the case, just in case i was getting a short from the standoffs (which i wasnt). this is really really confusing. i can take pics of the setup if needed. |
#23 |
Do the fets share the same heatsink? Are the heatsinks grounded? Did you put insulators between the transistors and the heatsink?
----------------------------------------------- Kilowattski |
#24 |
they do not share the same heatsink.
the heatsink is not grounded, but it is isolated from the FET and not touching anything. |
#25 |
hum, well, i checked ALL the zeners, the resistors and replaced the fets with new ones.
it doesnt light the light bulb anymore, it actually runs! but, i am only getting -60. on the + side, its only giving me like 8v or something. so maybe the 9610 died? ugh, this is so annoying because it all worked just fine before i started putting it all in the case. |
#26 |
I know how you Feel Cowanrg Just one step at a time and if you feel frustrated take a breather for the night. But always go back to the last thing you did and make sure you check it over maybe use a variac ?
Baby Danika, Born January 20th 1:54am.. http://itsparks.dyndns.orgMix a LittleUntangle&Opendns.org Perfect.. |
#27 |
well, unfortunately i dont own a variac
![]() im actually not THAT frustrated quite yet. i have made some progress, and i suspect its the fets. i had the boards just sitting out for a month or so on a shelf, so there was a good chance they could have shorted out or something. and im not 100% sure the replacement fets i had are good either. i need to sit down and test all the fets i have to make sure they all work ok. i did notice a few bad zeners too. its just a LOT of things going wrong with those boards... im almost tempted to just completely repopulate them (minus those MUR1520's though). |
#28 |
Maybe it's time to invest in an antistatic mat with the wriststrap.
http://www.electroflash.org.nz/produ...htm#Antistatic
#29 |
Id say invest in a variac first all your work has impressed me and i think it would be worth your whyle to buy one.. i did there not expencive either..
j'
#30 |
What good is a variac if your blowing up parts with static. Remember, Jason, the horse goes before the cart. There are ways to get around not having a variac. There is no way to get around blown parts. Antistatic storage bags are a good idea for boards until they are used.
| Poll! What do you use in your X-BOSOZ or BOSOZ for Volume Control and Input Selector? | promitheus | Pass Labs | 87 | 19th February 2006 04:15 PM |
| To BOSOZ or not to BOSOZ... please comment. | spence | Pass Labs | 2 | 24th December 2004 08:50 PM |
| X-bosoz vs. CCS X-bosoz, how does the sound compare? | acliao | Pass Labs | 14 | 26th February 2004 01:55 AM |
| Bosoz | lawbadman | Pass Labs | 5 | 14th July 2003 03:10 AM |
| 10K Pot for the BOSOZ | raincheck | Pass Labs | 13 | 20th September 2002 07:22 PM |
| Page generated in 0.10739 seconds (80.22% PHP - 19.78% MySQL) with 11 queries |
