#11 |
of course 800va is overkill
![]() the idea behind it was that i couldnt find a readily available xformer in the voltage i needed in a smaller size. and i WAS planning on doing full dual mono (two xformers), but at the cost plitron and others wanted to charge for two, i could get the 800va for less money. so, i just went that route. plus, it adds a good amount of weight to the chassis making it feel more substantial. |
#12 |
another thing regarding the light bulb,
does wattage matter? if there IS a short, will it blow, or will it just get really bright? i just want to know, if i HAVE a problem, do i have to worry about having another one
#13 |
RS Components has 2x55v toroids as of the shelf item. Maybe thats available in the states too? Here is the danish site:
RS toroids You should be able to interpret the VA ratings and the voltages. They have sales places in the states too. Steen
#14 |
i got the 800va for like $65. and i didnt have to track anything down. no phone calls, no emails, etc... i just clicked order, and it was there in a couple of days
and it looks cool for a preamp.
#15 | |
Check the diodes with your meter, if it has diode test? Might be that. Steen
#16 |
Yes, connect the light bulb in seies with the hot wire. I would say 50W to 100W bulb should do. If there is a short somewhere, the bulb will light up very brightly but won't blow out the bulb.
#17 |
yeah, ive got a diode tester in my meter.
steenoe, exactly. i just wanted some weight to the thing is all. and for $65, it wasnt much more than a much smaller xformer, and cheaper than dual ones! edit: i have some MUR860's or whatever those nice diodes are, could i use those instead of the 1N4005's? |
#18 | |
Schottky's should be fairly noisefree No snubbers needed Steen
#19 |
cool. ill have to see if i have enough of those to use for both boards... i think there are like 8 per board. not sure if i have that many.
now if i could just go home... |
#20 | |
Steen
| Poll! What do you use in your X-BOSOZ or BOSOZ for Volume Control and Input Selector? | promitheus | Pass Labs | 87 | 19th February 2006 04:15 PM |
| To BOSOZ or not to BOSOZ... please comment. | spence | Pass Labs | 2 | 24th December 2004 08:50 PM |
| X-bosoz vs. CCS X-bosoz, how does the sound compare? | acliao | Pass Labs | 14 | 26th February 2004 01:55 AM |
| Bosoz | lawbadman | Pass Labs | 5 | 14th July 2003 03:10 AM |
| 10K Pot for the BOSOZ | raincheck | Pass Labs | 13 | 20th September 2002 07:22 PM |
| Page generated in 0.11606 seconds (79.16% PHP - 20.84% MySQL) with 11 queries |
