balanced volume control
Old 6th September 2002, 08:32 PM   #11
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
balanced volume control Send a message via AIM to Peter Daniel
That's not too bad. For everybody considering that approach I suggest using fixed series resistor and change only the resistors to the ground with a switch, like Harry did in his passive pramp.
To order kits contact me through forum mail.
Old 6th September 2002, 08:34 PM   #12
Gabrielshorn is offline Gabrielshorn
Gabrielshorn's Avatar
Is that what you call a shunt attenuator? Changing the resistance to ground, I mean.
Old 6th September 2002, 08:45 PM   #13
Yes.
Old 6th September 2002, 08:52 PM   #14
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
We used a pot across the balanced output in the
DAC, as described by Peter. It works fine except that
it won't give you absolute zero volume. There is always
some residual output at minimum.
By the way, we bought a pile of those Electroswitch 23
position switches and regretted it. I have boxes of them
if anybody wants to make me an offer.
Old 6th September 2002, 09:04 PM   #15
jwb is offline jwb  United States
jwb's Avatar
Send a message via AIM to jwb
If you use that electroswitch non-shorting model, wont the volume go to maximum between positions? And wouldn't that be Bad(TM)?
Old 6th September 2002, 09:14 PM   #16
There must be something about those switches, because Sonic Frontiers were getting rid of them too. I have only 3 left.
jwb, in that location it has to be a shorting one.
Old 6th September 2002, 09:32 PM   #17
jag is offline jag  United States
Peter:
Instead of placing the pot between output and ground (4 needed) place the pot between positve and negative output of ea balanced channel (2 needed), so one stereo pot would work. This way, depending on impedance of the pot, positive and negative output will cancel each other without conecting to ground. You can find this setup in Pass D1 DAC.
Is this what you mean?
Old 6th September 2002, 09:55 PM   #18
Default More like this.
Taken from Denon high end ad. You can place pot either at the input or the output.
Old 6th September 2002, 10:20 PM   #19
skaara is offline skaara  Slovenia
Ill try peters suggestion tomorrow..
Old 6th September 2002, 10:32 PM   #20
Would be glad to hear your observations, I plan to use it in my upcoming preamp as well.
balanced volume controlHide this!Advertise here!
Balanced volume control question andyjevans Tubes / Valves 1 5th December 2005 04:12 AM
Balanced volume control? MWP Chip Amps 2 1st November 2003 05:36 AM
Aleph P 1.0 balanced volume control Grip Pass Labs 6 2nd October 2002 12:10 PM
Balanced Zen volume control Pete Fleming Pass Labs 39 30th August 2002 07:06 PM
balanced volume control diy student Solid State 2 16th January 2002 12:23 AM
