Soft Start and Standby Functions for your Aleph Amplifier - Page 8 - diyAudio
Old 16th November 2005, 05:52 PM   #71
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
Originally posted by pinkmouse
The full version?
SHHHH
Old 16th November 2005, 07:39 PM   #72
dr.strangelove3's Avatar
Here are all the optimasations Algar_emi recommended:
There is no real errors but things that can be improve before you go on
production.
One of my goal was to have a one side PCB, 4X6 inches lenght max because
I wanted to use a 9X6 one side PCB.
So, the things to improve are:
-The transfo on the PCB VA rating is a little to low to supply directly
outboard fans. I recommend to use a slightly bigger transfo, such as the
MT2228-ND, 18V, 0.7VA instead of the 0.34VA I used. You'll need to
increase slightly the dimension od the PCB to accept the bigger transfo
and chnage the transfo pins location, or as I taught to do, make
provision on the PCB to accept both transfo. You may be able to fit the
bigger traansfo by rearrange this section of the PCB.
-J1 & J2 are connectors that I got from a surplus store. You are better
to replace them from connectors that you can get from digikey, such as
nice little Molex connectors such as the Digikey WM5824-nd (this is a 3
pins conn, you need a 4 pins and maybe a little bigger, but you got the
idea.
-J2 is not well located, the others parts around are too close, so J2 is
kind of difficult to plug in, get some more room around it.
-U2 is too close to D1. You need to install a DIP socket to plugin U2.
Bring U2 more to the right of the PCB
-RLY4 is a little to close to the screen mounting hole. You may move the
PCB right side of the PCB to get some more air on the right section of
the PCB.
-U3 is really close to Q1, again move the right side a little bit to the
right.
-Add an other piin hole for maybe an smaller dimension and or type of
capacitor for C35, as I did with C34 (optional)
-You may add 0.1uF, decoupling cap for U2 and U3 on the supply pins. I
was planning to add them from under the PCB if needed.
-A last request, if you get a silkscreen option, would you right my name
in full on the PCB along with the copyright?
Old 16th November 2005, 07:50 PM   #73
I am wondering about the mains dc filtering. I takes up quite a lot of space. I can do without that section.
Old 8th December 2005, 09:53 PM   #74
Although I like this design, I myself have decided not to go further with this design.
I have started designing something similar but very different.
I hope to have a working prototype in a few months.
Old 30th October 2007, 01:29 AM   #75
Hi guys, think im 2 yrs late on this thread... Just a short question: where should we insert the Standby switch on the Aleph circuit? I understand it should be somewhere around Q3 on the main board?
Old 30th October 2016, 03:39 AM   #76
leaseba is offline leaseba  Argentina
Im very much interisted, can you please send me PDF the higher resolution.
leandrost@arnet.com.ar
Old 13th January 2017, 08:44 AM   #77
Can you please send me the higher resolution?
hilhan79@gmail.com
Thanks.
Soft Start Necessary? dtaylo3 Class D 2 26th December 2008 09:05 AM
B+ soft start Gluca Tubes / Valves 2 3rd September 2007 01:04 PM
Need a soft start? maxpou Solid State 19 18th April 2007 09:23 PM
Soft start & Soft Switch circuit: can anybody help? m.parigi Solid State 95 22nd August 2005 03:32 PM
Copyright 1999-2017 diyAudio
