#41 | |
nope common mode type choke work even better in psu....
#42 |
Do you smell smoke?
A core that size, especially a toroid, isn't going to handle anywhere near that much current...
Try the Hammond 159ZE, a bit pricey, but well worth the money... Roscoe |
#43 |
differential mode choke ( big one ) is the way to go
flux cancellation blahblah Fuzzy ZM
my Papa is smarter than your Nelson ! tnx to thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
#44 | |
THX, -Joe |
#45 |
Do you smell smoke?
About the size of the previously mentioned Hammond 159ZE....
Roscoe |
#46 |
big in value , or big in size ?
lookielookie : The NEM AI-50 observe value of L2 hop to 6moon article , read , study CRO photos use PSUD to decide what's enough for your particular case
#47 | |
![]() Since NP suggests 1.5-2.2mH, I will continue looking for a suitable surplus toroidal unit... -Joe |
#48 |
#49 |
I've been running a lot of PSUD simulations recently on choke input filters. Sometimes I get a warning that the rectifier reverse voltage has been exceeded. The voltage spike comes right at the zero crossing of the transformer voltage.
Usually the big peak in transformer current comes after the transformer voltage peak. (Current lags voltage in an inductor.) If you get the load current and capacitance just right, the current peak is very near the center of the voltage peak and looks like the current peak you normally see with capacitor input filters. No spikes. If you put a smallish capacitor on the rectifier side of the choke, you can increase the voltage between the choke input value and the cap input value. The problem becomes finding a cap that can withstand the ripple current. Power factors (power out/power in) run about 60-65% with cap only or CLC filters. About 10% higher with LC filters. Note: To get PSUD to spit out valid RMS numbers, run the simulation for 100mS to get 5 complete cycles at 50Hz or 6 complete cycles at 60Hz. Then you get pretty good numbers for the currents in all the components. There is also a feature that lets you calculate the transformers bulk impedance from the winding resistances and no load voltages. I use a 2 second delay, but you can get a big voltage spike at turn on. Check what goes on with zero delay. I guess I'll be shopping for thermistors soon. |
#50 | |
Does PSUD simulate use of one CL 60 on each primary line lead to traf? If so, how does this affect the peak voltage on rectifier(s)? Thx, -Joe P.S. Loudthud:If you want I can send you a spare pair of CL60 I have lying around(PM me). Last edited by jtsaudio; 29th January 2012 at 05:41 PM. Reason: postscript |
| Choke input power supply, capacitor ratings | 00940 | Tubes / Valves | 14 | 7th July 2009 05:52 PM |
| Choke Input Filter. | G | Tubes / Valves | 8 | 11th February 2008 08:57 PM |
| Using Choke in LCRC filter in power supply | vangogh-hk | Tubes / Valves | 5 | 24th November 2005 05:21 PM |
| SOZ Choke input filter? | gnomus | Pass Labs | 48 | 14th May 2004 06:41 PM |
| Choke input Power Supply | NickC | Solid State | 4 | 6th November 2002 07:41 PM |
| Page generated in 0.10248 seconds (79.41% PHP - 20.59% MySQL) with 11 queries |
