I am going to use one 500VA 2x35V transformer to drive both rails. I yesterday drafted schematics of the psu and I would appreciate if some could check that I got everything right and reached Mr Pass' idea.
This because I don't have any EE training. |
#2 |
Hi Sella, That drawing seems perfectly OK to me.
Steen |
#3 |
Account Disabled
Two 1.5A fuses...?
I would use one 3A fuse, and replace another one with CL60 (or equivalent) thermistor. Regards |
#4 | |
Hi Sella, It should work fine, but I would go to CRC or CLC. 25mf->1 Ohm->25mF, or 25mF->2mH->25mF or so... Adam |
#5 | |
Steen. |
#6 |
I agree with steen - I have tried a CRC filter in my Zen 4, and besides the heat in the resistor (0,47R) I didnt notice any difference, either in noise or sound. The regulated supply is doing a good job i think, and if you build the amp on a breadboard, and leave the regulated supply out of the circuit, I would use either CLC or CRC.
Besides that, I would use 50000uF pr. channel - but try with 25 and then the double value, mabye you will notice no difference. I also think that 250VA / channel is cutting the hair short on the trannie - I use 750 VA, and get noticable heat on the donut. I you want to play with the BIAS - and bellive me you do want to play with it, IF you have the heatsink for it - I would go for 500VA pr. channel. Upping the bias adds a lot of spatiality and detail to the amps sound. |
| newbie with input tran. question and wiring question | imo | Solid State | 0 | 18th January 2006 10:10 PM |
| Capacitor Question /question on cap | TunaFish | Tubes / Valves | 14 | 12th January 2004 02:23 AM |
| PS question - tformer question actually | breguetphile | Chip Amps | 2 | 30th May 2003 01:29 PM |
| old speaker question, bullet midrange question & link to speaker project | wallijonn | Multi-Way | 10 | 5th November 2002 06:03 AM |
| Page generated in 0.07346 seconds (82.68% PHP - 17.32% MySQL) with 11 queries |
