Old 3rd September 2002, 09:52 PM   #1
2Bak is offline 2Bak  Denmark
Default Zen 4 heatsinks
Found two old heatsinks, on which I do not have the heat dissipation data.
They measure H x W x D, 220 mm x 200 mm x 70 mm.
Would there be a chance that they are able cool down the Boz 4 @ 2 x 30 watt or 2 x 25 watts?
one sink for each side
tanx
Old 3rd September 2002, 10:40 PM   #2
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
I'm afraid they are not enough. But if you stack them face to face and run a fun they might be OK.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 4th September 2002, 06:20 AM   #3
Thanks Peter Daniel
I might consider a fan.
I'm not quite sure what stack them face to face means...
topview:
is that it?
Are silent fans for CPU cooling applicable for amps?
regards
Jan Bak Madsen
Old 4th September 2002, 06:36 AM   #4
Default Works good
Hallo 2Bak,
i use these sink also with my zen (bias 3,5 A - 43V).
So i´m dissapating 150W. Hot, but under 55 GradC.
Go for it.
Andreas
Old 4th September 2002, 09:17 AM   #5
Account Disabled
Default 2Bak
I use the size:
H: 250 mm
W: 230 mm
D: 65 mm
Number of fins: 18
Two FETs are fitted on one sink--average 2A each at DC supply of 32V.
It's rather hot--about 50 degC at room temp 27 degC.
Mine should have been a bit bigger.
I recommend you to increase the size.
Hope this helps...
JH
Old 4th September 2002, 12:33 PM   #6
Default I'm not quite sure what stack them face to face means...
I was rather thinking about something like this and placing a fan at one end.
www.audiosector.com
Old 4th September 2002, 12:45 PM   #7
Account Disabled
Face to face...?
I hardly see who have full of hair on the face.
Hahaha...
Good night.
JH
Old 4th September 2002, 12:55 PM   #8
Originally posted by jh6you
Face to face...?
JH
Just a different culture.
www.audiosector.com
Old 4th September 2002, 05:24 PM   #9
well, this will be a hard decision for me to make. Was hoping for a few more of them "go for it", like Orgonoms...
Also found an EI transformer 800VA, 2x18v. Guess you guys will turn your thumbs down on this transformer type also?
Weight 10 kilo = 22 pounds lb
175x135x115 mm
Old 4th September 2002, 05:36 PM   #10
HDTVman is offline HDTVman  United States
Hi 2Bak.
I'd use it if you have room. Why buy when you have a x-former like that in hand.
later
Bruce
What ever makes the tunes flow
To-3 Heatsinks sandstorm33 Swap Meet 8 6th February 2008 04:33 PM
about heatsinks bigpanda Solid State 2 4th May 2005 03:34 PM
Heatsinks DD_Davo Chip Amps 2 13th April 2005 01:00 PM
Heatsinks Peter Daniel Swap Meet 19 3rd February 2004 11:08 PM
Heatsinks for DoZ ultrachrome Solid State 0 4th February 2003 09:23 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
