Zen 4 heatsinks
Zen 4 heatsinks
Old 4th September 2002, 06:03 PM   #11
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
Zen 4 heatsinks Send a message via AIM to Peter Daniel
Although big, that transformer is probably better than toroid.
To order kits contact me through forum mail.
Old 5th September 2002, 02:32 AM   #12
jh6you is offline jh6you
Account Disabled
I use both EI and toroidal transformers.
I prefer EI type though its physical size is big. My ears detect a bit relaxed-muscle sound with the EI type.
During DIY life, I have been much concerned on the poor quality of transformers. I have been kind of short-tempered mostly with the transformers. If the amp designer recommends, e.g. 300VA transformer, Id like the VA size of one step bigger. And, I prefer the transformer made for the 50Hz AC supply. A well-known story is that The 50Hz AC transformer is no problem when it is moved to the 60Hz AC zone, but the 60Hz AC transformer is almost always problem when moved to the 50Hz zone.
Hope you to check and select the right one.
JH
Old 5th September 2002, 07:39 AM   #13
Orgonom is offline Orgonom
Default Again, go for it!
Maybe a pic makes it easier to go for it.
It runs now for ca. 1,5 years without any
problem.
Andreas
Old 5th September 2002, 07:50 AM   #14
2Bak is offline 2Bak  Denmark
thanks Orgonom
I think I'll go for them.
Old 5th September 2002, 08:41 AM   #15
boessenkool is offline boessenkool
Default about the transormer
Dear 2BAK,
Having built my second JLH 10W amplifiers with EI transformers, I must say that the humming of the transformers I used is really frustrating (again). But this time I'm aware that the humming of the transformer is the problem and not the earthing, the circuit or something like that.
I am solving the problem right now, by placing the transformers in a separate housing.
Just curious, how heavy is the transformer?
Wishing you all the best.
Luuk Boessenkool
Old 5th September 2002, 09:07 AM   #16
boessenkool,
10 kilo.
The guy who sells them to me has two of 'em. Thus I can build monoblocks if I want to...
He says that humming and noise in an amp would not be caused by them, but by wiring problems and maybe the position of the trafo in the case....
/Jan
Old 5th September 2002, 09:39 AM   #17
Dear Jan,
Who knows.....
At least for my amp, I know for certain that the EI transformer is the problem. With all wires still connected I moved the transformer around and when the transformer was outside the casing, the hum disappeared.
All I meant to say was, that with such a transformer hum is a real posibllity.
Greatings,
Luuk Boessenkool
Old 5th September 2002, 04:58 PM   #18
Account Disabled
Luuk
Hum when the transformer is installed inside the casing and no hum when installed outside the casing...? Then, your transformer is fine because the transformer outside the casing is OK. I would like to say that the hum is due to an improper wiring arrangement inside the casing.
JH
Old 6th September 2002, 12:35 AM   #19
Account Disabled
Andreas
Your amp looks nice and looks better than mine.
By the way, for the capacitors, why not wiring as in Fig.(B)...?
I mean to persue a possibility of minimal hum and buzz.
JH
Old 11th September 2002, 10:25 AM   #20
Eccu is offline Eccu  Finland
Eccu's Avatar
Or why wiring like fig (A), but wires to amplifier take from upper capasitor.
right way boy... u sold farm and bougth booze
Zen 4 heatsinksHide this!Advertise here!
To-3 Heatsinks sandstorm33 Swap Meet 8 6th February 2008 04:33 PM
about heatsinks bigpanda Solid State 2 4th May 2005 03:34 PM
Heatsinks DD_Davo Chip Amps 2 13th April 2005 01:00 PM
Heatsinks Peter Daniel Swap Meet 19 3rd February 2004 11:08 PM
Heatsinks for DoZ ultrachrome Solid State 0 4th February 2003 09:23 PM
