Old 30th April 2005, 05:35 PM   #1
Default Pass Aleph P1.7 Help needed
Hi all,
i am currently building an Aleph p 1.7 clone.
PCB comes from http://web.vip.hr/pcb-design.vip/aleph-17.html
Test show that the amplification is not working properly:
With an input voltage of 450mV I get 1.05 V output max.
I tried all Input Switch Positions.
The 9610 are running very hot (85 degree C).
Does anyone who already built an Aleph P 1.7 have the voltages over Mosfeet and Bipolar Transistors and can send these value to me.
Any help is highly appreciated.
Thanks and All the best
Old 30th April 2005, 05:45 PM   #2
acaudio is offline acaudio  Germany
For first you should measure the voltage loss across the source resistors (22 respective 33 Ohm)
The voltage loss should be at aprox. 0,65V
Adam
Old 30th April 2005, 06:55 PM   #3
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
Remove the . from the end of your link .. : O )
J'
Old 1st May 2005, 02:25 PM   #4
Adam
Hi acaudio,
the voltage across the source resistors is 0.62 and 0.66 V.
Any other ideas ?
Old 1st May 2005, 07:32 PM   #5
Originally posted by fschlenk
Hi acaudio,
Any other ideas ?
Hello,
which value of gain potentiometer has you used?
2K as in original?
Adam
Old 1st May 2005, 08:24 PM   #6
Hello,
2K as in original?
Adam
Hi Adam,
I tried with the 2k pot. But the amplication is not affected by the setting. Now I use 768R fixed.
Old 2nd May 2005, 02:46 AM   #7
aht is offline aht  Thailand
Account Disabled
Send a message via ICQ to aht Send a message via MSN to aht
Default Do you want my PCB
Give me your PCb design or post it here.
I'll be compare & check PCB line. You may be get a wrong design of PCB.
Now I use AlephP1.7 ,too.
It's sound nice with Evox capacitor 12uF*8/63V.I'll be compare with Panasonic FC series soon.
If you want my PCB's design & bias test point can email me for send it.
Regard
AHT
Old 2nd May 2005, 10:56 AM   #8
kilowattski's Avatar
AHT,
He is using a proven PC board. If you read his first post you will see he is using a PC board designed by Kristijan Kljcaric of PCB-DESIGN. The boards have been used successfully by many members of this forum.
Kilowattski
Old 2nd May 2005, 11:12 AM   #9
fschlenk,
If you are using an attenuator or potentiometer on the output please disconnect it then remeasure the gain. Remember that the output is 1/2 if your are using the single ended input. If you are using single ended input remember to short the negative input to ground. Also remember that the internal attenuator switches need jumpers in position 1,2,7,8 and 3,4,5,6 should be open for zero dB input attenuation.
Kilowattski
Old 2nd May 2005, 11:17 AM   #10
Account Disabled
If the voltage measures about 0.60-0.7 accross R44/55/59/70 and about 30V at the drains of 9610s. Nothing is wrong.
Mayby Nesson Pass is wrong!!!
Pass Aleph L 1.2?Maybe O.T. michelangelo Pass Labs 10 24th March 2009 03:22 PM
Pass Tharagard A75 vs Pass Aleph 1.2's daly41k Pass Labs 7 18th February 2007 03:10 PM
pass aleph P VS pass X2 first version perusicchio Pass Labs 10 5th March 2004 10:06 AM
Pass Zen V4 All parts needed 4 sale mg16 Pass Labs 3 16th April 2003 11:21 PM
transformer voltage needed for Aleph 4 or Aleph 2 diy student Pass Labs 23 28th November 2001 07:54 PM
Page generated in 0.10626 seconds (78.05% PHP - 21.95% MySQL) with 11 queries
