#11 | |||
In the case of an antenna, half the antenna is connected to the circuit's input and then to the other half of the antenna through a load impedance, the other half of the antenna being tied to ground. However in this case, we just have a wire that's open at one end and the other end terminates at the ground node. Now according to Kirchhoff, the current flowing into that node must be the same as the current flowing out of it. So if you've got current flowing from the wire into the ground node, where is that current going in order for it to flow out of that node? se |
#12 | |
Cheers, LarryO |
#13 | |||||
From a purely shielding perspective, it seems to me that the shield sound be an extension of the chassis and connected at both ends. However this can bring about its own problems as mentioned above. se |
#14 |
Master Burner
I am sure that these articles will help you. I find them very informative regarding ground woodoo.
http://www.rane.com/note110.html http://www.rane.com/note151.html AR2 |
#15 | ||||
Following up on the conversation with SteveE, the folks at Rane stated the issue with more clarity than i did.... Quote:
What I discovered was that the fog surrounding this subject was effectively lifted by the work of many in the AES, such as Neil A. Muncy and Ralf Morrison. And shown to be effective by Tony Waldron and Keith Armstrong who performed some key experiments that fully supported the proposed techniques. The later was a great read, here's an excerpt... Quote:
1) Never connect a circuit's "signal ground" to the chassis. 2) Never connect the main's "earth" line to the circuit's "signal ground". 3) Always connect the mains "earth" line to the chassis. 4) If using a "Y Filter" on the mains lines ("hot", "neutral") for common mode noise supression, reference the legs to the mains "earth" line at the point it connects to the chassis, and mind rule (2). 5) All signal interconnects should be fully balanced. If this is not possible (legacy equipment, circuit constraints, etc.), then noise performance will be compromised. 6) The "shield" of an interconnect should be connected to the chassis at both ends of the cable. And, that connection is best if it completely envelops the cable/connector junction (so called 360 degree connection) without the use of "pigtails". 7) It is best if each chassis is additionally strapped to a ground reference point by a very low impedance (inductance + resistance) connector. 8) Internal shielding to segregate noisy/dirty circuits is a good idea. 9) Contrary to conventional thinking, a "meshed ground" is better than a "star ground". This is true whether doing circuit board layout or lightning protection systems. AND, the following related notes were taken... 1) 2) Should one 'correct' legacy equipment? 3) There is a branch of equipment design, called "double insulated" that intentionally does not adhere to this practice and it would be a bad/unsafe idea to alter such designs without specific expertise. 4) These filters use special capacitors that always fail to an open-circuit condition so do not think "audiophile" for this application. 5) This is the big hitch in the getalong. There is a gaggle of legacy and, sad to say, current equipment that does not support this highly logical principle. There are a number of possible solutions that can be applied to this situation. Note 110 from Rane, cited above by AR2, has a nice discussion of this and a handy table. The issue of floating one end of the "shield" is delt with extensively. I could find no solid engineering to form a rule for which end (source or target) to bond the "shield" to and which end to 'float'. I can say that more often I noted that the shield was tied to the target (input circuit) end of the cable. There was much said about the effectiveness of using a small (1 - 100 nF) capacitor between the "shield" and the chassis/signal ground at the 'floating' end of the cable. This completes the circuit for RF frequencies and blocks the low frequency 'ground loop' currents. Seems like solid concept and often recommended, but a challenge to implement physically. 6) The "360 degree" vs. "pigtail" connection techniques have more significant affects above about 30 MHz so for audio gear (sans digital circuitry) this level of attention may have diminushed return. 7) Lots of talk about this, especally related to lightning safety and in situations where there is significant distance between component equipment and the chance of higher "ground potential" (remember, there's no real "ground") differences is greater. One highly interesting point was that copper foil ribbon (say 0.011 x 2.0") has lower impedance than a #6 copper wire, and is much easier to handle too (remember to avoid sharp bends). For good discussions on this topic see the ARRL and other HAM sites. 9) This was one of those ratholes that I spent some time reading on as it was so contrary to what I thought I knew. Bottom line is that it works, and for good reasons. Trouble is that I have not (yet) found a good reference on "how to mesh ground" for general circuit wiring/layout techniques. Star grounding on the other hand has been addressed many times and seems almost intuitive. That's what I gleaned from my little oddesy into the world of grounding and shielding. Maybe some of the more learned here will correct the things I've misinterpreted or help answer some of the open questions. Cheers, LarryO |
#16 |
Here are some articles I found to be informative...
Designing for Interference-free Audio System Components Design Techniques for EMC cables and connectors Bonding Cable Shields at Both Ends to Reduce Noise A Practical Interference Free Audio System (Part 1) A Practical Interference Free Audio System (Part 2) Grounding and Shielding Audio Devices Sound System Interconnection LarryO |
#17 |
Larry,
You may also like to look at this: http://www.analog.com/UploadedFiles/...8865AN-202.pdf (ADI AN-202). Not strictly about cabling and screening, but defitively On Topic. Jan Didden
/Another new issue: Linear Audio Volume 3! |
#18 | |
Master Burner
Hi LarryO, Could you please post the link to this articles.
#19 |
Sorry, just have the docs. All should be a 1st pg hit on Google.
| "cable chargers" - DC biasing cables? | dorkus | Everything Else | 20 | 21st June 2002 07:41 PM |
| Page generated in 0.16357 seconds (87.25% PHP - 12.75% MySQL) with 10 queries |
