I need your help. I just finish an Aleph30 and it is huming.
I tried some modification, it help a litttle bit but a hum is still here. How this is possible: -When I connect only one input of the amp, there no hum at all. -When I connect the 2 input of the amp, I have hum in the 2 channel ???? The only difference I have between the 2 channel is, the cable between the bridge and the PSU is 4 inch more long on one side, I don't think this can effect any thing.... I don'T know how to get out this noise of my amp. Thank you |
#2 |
HI,
this is a typical ground loop. Where did you connect you input grounds? Did you use the ground lift resistor at the input? Try to draw a schematic with ALL the ground connections, most of the time youŽll see the ground loop when drawing. William
een ooievaar is geen konijn want zijn oren zijn te klein! |
#3 |
The one and only
The usual solutions:
a) rotate the transformer to minimize the hum b) attach a solid wire between the RCA grounds and use it's center point as the star ground for the input and output grounds of both channels , and send only 1 wire back to the power supply ground. also, it's very useful to ground the chassis well to the AC outlet ground and then attach the circuit ground to the chassis through a power thermistor like a CL60 or through diodes to give some loop isolation while retaining a safety connection.
#4 |
wuffwaff: I connect the input ground in the PC Board.
In my circuit board, there a "ground" connect to the power supply and the other "ground" is connect to the speaker output. So, you think it is a good idea to remove the inout ground to the PC Board and to put a peace a wire between the RCA input directly to the chassi ground ?? Thank |
#5 |
IŽm not shure. It would like to see a schematic of some sort. HereŽs what I usually do: I always try to make some kind of star earthing with one central point per channel. As central point I usually take the main power supply caps. In my A5 IŽve got two earth points, one for each channel. The two channels are not directly connected. Both earth points connect to the chassis via a bridge rectifier. The chassis is connected to mains earth. If you connect both channels to the chassis the you get a ground loop via the preamp. hope this helps, William
#6 |
Yeah,
Me, My 2 channel are connect to the chassis to a single point..... but if I disconnect from it, the hum stay... But.... I have to ground only 1 channel??? I don't understand very well... Thank you |
#7 |
Account Disabled
I believe that Nelson Pass adviced us in the most correct way.
Nevertheless, I always do this way successfully. Due to increased number of wires, it might look stupid. But, it works very well for me. Hope this info will help. Regards |
#8 |
Ok, If I make this schematic, I have to remove the cable between the RCA connector and the PC board or I leave them here and I add and other wire in parallele with the one here ??? I hope you understand what I'm saying ???
#9 |
Lightning In A Bottle
This is why I love making my chassis out of wood (cheaper, easier to cut). I just connect all grounds to a bus bar with enough screws. I still utilize "a diode bridge over troubled waters" though.
#10 |
The one and only
Like the diagram from Jh6you, it's important to run a wire
from the star point off to the heavy short wire between capacitor grounds and a wire off to the heavy short wire between the RCA input grounds. This keeps the ripple voltage on the capacitor wires off the signal ground and the transformer magnetic field from creating a noisy input ground (via a loop back to the source component grounds) that gets amplified. If there's a ground wire coming from the transformer, it should sit on the heavy short wire between capacitor grounds, not at the star ground. Just my noise contribution... |
| BJT for Aleph30 | same | Pass Labs | 1 | 5th May 2007 03:48 PM |
| Help Aleph30 | Kooka | Pass Labs | 9 | 18th February 2007 02:03 PM |
| Hum.....Huming Aleph 4 ... Help! | Prince134 | Pass Labs | 10 | 22nd June 2005 02:08 PM |
| Aleph30 very very hot | arold19 | Pass Labs | 7 | 12th February 2005 01:55 PM |
| 1 Ohm For Aleph30 | gema | Pass Labs | 2 | 30th May 2002 07:40 PM |
| Page generated in 0.10860 seconds (78.19% PHP - 21.81% MySQL) with 11 queries |
