Old 17th April 2005, 10:19 PM   #1
Metric is offline Metric  Norway
Default Question to Mr. Pass
Hi!
I am thinking about bying a second hand x250 to use with ML Summit. The panels on these speakers can reach 0.7 ohms. Will this be a problem for the x250?
Thanks,
Per Øyvind
Norway
Pass Labs x600, x1, ML Odyssey, Marantz SA-11S1, Syneristic Research cables
Old 17th April 2005, 10:29 PM   #2
Default And one more thing
Are the early x250 the same as the latest versions, or have they been opgraded at one time? From serial number xxxxx for instance?
Thanks again,
Per Øyvind
Old 18th April 2005, 05:15 PM   #3
The one and only
Nelson Pass's Avatar
The X250 has been replaced by an update, the 250.5. It's
ability to drive the low impedance of the ML's is about the same.
The .7 ohm figure is not a difficulty, as it occurs up about 15 KHz
or so, where there is very little actual energy, so we don't see
it as a practical problem, as long as an amp is stable into the\
impedance, which the 250 is.
Old 18th April 2005, 05:23 PM   #4
But all the x250's are identical, right? No matter if it's a2001 or 2004 model?No different versions there besides the x250.5?
Maybe some of the members out there know this as well?
Thanks again,
Per Øyvind
Old 18th April 2005, 06:59 PM   #5
kilowattski's Avatar
Didn't Mr. Pass just say that there has been no changes in the X250 until the X250.5 came out? Maybe it's just me??
Kilowattski
Old 18th April 2005, 08:26 PM   #6
I'm really sorry Kilowattski. This will not happen again. Thanks for showing me my place.
Old 19th April 2005, 06:16 PM   #7
The one and only
Well just to clarify, there are parts changes made over the
life of an amp, and we tend to incorporate some improvements
in a product before releasing an updated piece without changing
the topology of the circuit. This makes the product incrementally
better or solves problems, and is often a balm to those customers
having purchased a product before a revision is released.
In the case of the X250, the last year's production had improved
transformers, rectifier bridges, and other minor items, but the
overall performance remain distinctly X250. The 250.5 included
actual topology changes to the circuit and also new handles.
Old 19th April 2005, 10:13 PM   #8
Thanks a lot, Mr.Pass. I look forward to hooking up the x250 to my not yet arrived ML's
To Low Pass Or Not To Lowpass...That Is The Question CarlosT Full Range 2 18th December 2006 11:45 AM
Question for Mr.Pass Metric Pass Labs 5 27th May 2005 09:17 PM
A75 question for Mr Pass demons_wing Pass Labs 13 25th April 2004 08:21 AM
Question for the One and Only. (Mr. Pass) K-amps Pass Labs 7 4th February 2004 06:35 PM
A Question for Mr. Pass (and all..) W.O.L.F. Pass Labs 4 12th March 2003 12:59 AM
Page generated in 0.10072 seconds (76.73% PHP - 23.27% MySQL) with 10 queries
