Help, I finished one channel of my Z4 last night (enough to give her a try) Voltages seen ok but very little gain, lots of distortion and very hot in the area of c10. the pcb and mosfets are well mounted on a very large heat sink.
Thanks in advance for the help, Ralph ps: i am a radio ham and this is my first real audio project.
#2 |
Hi Ralph and welcome.
What do you mean with 'very hot in the area of c10' ? Is C10 getting hot or the zeners or...? /Hugo
#3 |
it seems that c10 is the source of the heat, but i am not sure...
#4 |
Ralph,
R0, R1 are close to C10 and apart from the mosfets they are about the hottest parts in the amp. What source did you use to feed the input? /Hugo |
#5 |
Hugo,
It seems that C10 is the source of the heat but i will check again tonight. I am using the headphone output from another amp for test purposes - as sooon as i get this Zen4 up and running i plan to build a preamp. Thanks for the help, Ralph |
#6 |
If you have a multimeter check C10 to see if it is shorted. Also check the board for solder splashes and to see if you have the right components in the right spots. Triple check it. Did you use the component values as called out in the article? You say the voltages are correct. Make sure of this because it can give us a hint when helping you. It would be handy to note the exact voltages you read.
----------------------------------------------- Kilowattski |
| Sick Carver M-1.0t amp: bad caps? | sblack6 | Solid State | 1 | 7th June 2009 07:53 AM |
| Got this on this on ebay..sick amp | benny_rx_blanco | Car Audio | 2 | 8th April 2009 10:18 PM |
| New sick amplifier | Solosound | Car Audio | 3 | 5th December 2008 01:29 AM |
| My Linn Axis is Sick. Please help fix | bubbamc119 | Analogue Source | 53 | 26th January 2008 12:08 AM |
| My Fender 6G15 is sick | bassman314 | Instruments and Amps | 8 | 29th January 2007 02:54 PM |
| Page generated in 0.07810 seconds (76.18% PHP - 23.82% MySQL) with 10 queries |
