Old 14th April 2005, 11:43 AM   #1
Default Any connection between Aleph dynamics and transformer!
Is there any connection between sound (especially dynamics) and the transformer rating?
I'm asking this because I have two 300VA toroids per channel in my Aleph 5, and now I have some extra cash so I thought it would be good to make my Aleph better.
What can I expect from 500VA per channel?
Old 14th April 2005, 07:14 PM   #2
Netlist is offline Netlist  Belgium
Netlist's Avatar
Because current in class A amps is constant and the 300VA’s seems to be able to do the job, you will gain nothing with replacing them with 500VA’s.
/Hugo
Old 14th April 2005, 07:48 PM   #3
Thanks. I thought so, but I wasn't sure after I red Nelson's "Power supply" paper!
Old 14th April 2005, 08:51 PM   #4
Blues is offline Blues  United States
Lightning In A Bottle
Blues's Avatar
I believe it will help any Aleph. The Aleph's current source, besides a 0% ACIG setting, will try to deliver more current in lower impedances in Class AB. Having a transformer only able to deliver an Aleph's rated Class A power will be strained in my opinion and might sound hard depending on your speakers' impedance variations. The feedback on the Aleph current source sets the current sharing in the +/- signal and also allows the Aleph to deliver Class AB power beyond its Class A DC bias.
Old 14th April 2005, 09:02 PM   #5
wuffwaff's Avatar
up until 50% ac current gain the mean power taken from the power supply will be the same all the time regardless of signal.
This doesn´t mean that other transformers will sound the same as they also function as mains filters, sources for magnetic fields etc. etc.
I think the power supply caps are (generally speaking) more important for dynamics cause they have to deliver the short peaks needed. So before you invest in bigger trannies you could try more caps......
William
een ooievaar is geen konijn want zijn oren zijn te klein!
Old 14th April 2005, 09:38 PM   #6
The one and only
Nelson Pass's Avatar
I think it's a question of diminishing returns. A constant average
draw design like the Aleph is less sensitive to transformer
rating once the minimum requirement is met, but we still like
them bigger, don't we...
Old 14th April 2005, 10:13 PM   #7
Banned
Netlist []
Poseidon's Horse
Offline
Post #2
you does gain more reliability and easthetic appeal arent you
guys do the same thing to look like those professionals making
high-end stuff, and dont forget the other stuff like overrated heatsinks and gold plated stuff etc
need help on transformer secondaries connection atenolol50 Tubes / Valves 6 26th September 2008 08:52 AM
Transformer Leg Connection Question mark845 Tubes / Valves 3 6th August 2006 02:31 AM
Best Aleph bi-amp connection Sony Pass Labs 9 26th February 2005 10:06 PM
Transformer connection for BOSOZ Yochim Pass Labs 3 6th September 2002 05:45 PM
Aleph 3 R114 connection Forte Pass Labs 4 30th October 2001 11:17 PM
Page generated in 0.07743 seconds (81.82% PHP - 18.18% MySQL) with 10 queries
