Old 12th April 2005, 12:50 PM   #1
Send a message via AIM to Mattyo5
Default Biggest Aleph 2's yet?
Ok, here they are!
http://www.briangt.com/gallery/aleph-mattyo
Thanks Brian for hosting!
Thanks JRSUN for the boards!
Thanks for my family and wife for putting up with me during this project. $1500 (approx) and 200 hours of work over almost 2 years. Wow. When i turned them on, they worked, first shot. No flames, no magic smoke.
I do not have a pic of the back of the amplifiers yet. I'm gonna put in a switch to switch between high and low bias (and corresponding changes in ACIG). Right now they are running at 8A bias, and the sinks get probably close to 120degF. There are 16 fets per channel, 1kva avel toroids wrapped in rubber, 320kuf in the power supply per channel, z5 bypassed w/ BC 1uf polypro, cardas rhodium output banana jacks, balanced and unbalanced inputs, mills source and output resistors, handmatched output fets to 10mV and handmatched irf9610s to w/in 1mV. DC offset is below 50mV for both channels. I used my dad's milling machine for quite a bit of the work. and i got the heatsinks from ebay a long time ago, and the aluminum as well.
http://cgi.ebay.com/ws/eBayISAPI.dll...sPageName=WDVW
thats the aluminum guy
i used 1/8" aluminum for the front and back plates, and 1/4" for the bottom, and 1" x 1" x 1/4" angle all around, i even used brass screws as much as I could, $75 worth!
hmm what else, how do they sound....liquid. just gorgeous! Thanks so much Nelson for allowing us to use this design. What a fantastic amp!
i'll try to post more pics of the back and of the grills when i get them done. Thanks again Brian for hosting!
-Matthew K. Olson
Old 12th April 2005, 01:29 PM   #2
pinkmouse's Avatar
Very impressive Matt. Well done.
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 12th April 2005, 01:47 PM   #3
Thanks!
The wiring was a little easier to get right with this project considering i had PLENTY of room inside the case
-Matthew K. Olson
Old 12th April 2005, 02:18 PM   #4
jrsun is offline jrsun  United States
Matthew,
8A per channel ? Wow! considering 3A only in Alpeh-2.
Pictures please ! I'm going to build A2s too, see if I can get any close to yours !
Old 12th April 2005, 02:21 PM   #5
its 4A bias per rail...i think thats 8 total per channel. Rails at 44V under load i think. Bias is VERY stable.
good luck w/ yours!
-Matthew K. Olson
Old 12th April 2005, 02:31 PM   #6
the AC current gain ?
Old 12th April 2005, 02:40 PM   #7
i dunno yet hehe i have a pot to adjust things, rightnow its stock value.... i'll let you know as soon as i figure it out
-Matthew K. Olson
Old 12th April 2005, 03:39 PM   #8
sklimek is offline sklimek  United States
sklimek's Avatar
Wow, the proud Father of a set of beautiful twins! Congragulations, it must have been quite a journey!
Where did you get those PS Caps?
Thanks for posting - Stan
Old 12th April 2005, 03:56 PM   #9
The caps are actually used. Got em again on ebay. I bought almost 30 of them for pretty cheap. They all hold voltage just fine though, and i powered them up real slow to reform them. No problems there!
-Matthew K. Olson
Old 12th April 2005, 04:18 PM   #10
HI Matthew,
CRC or CLC ? just wonder if any sound difference from differnt level of ripple ! Also any perceivable difference with and without z5 bypass cap ?
another biggest, most, tomtt Multi-Way 3 21st October 2008 04:08 AM
The biggest bunch of tubes ever seen Trout Tubes / Valves 74 21st May 2008 10:20 PM
Amp that has the biggest number of irons vax9000 Tubes / Valves 3 26th July 2006 04:42 AM
Biggest Spl Per £ bob123 Subwoofers 10 25th April 2006 09:50 PM
Biggest amp skyraider Chip Amps 40 8th November 2004 06:57 PM
Page generated in 0.10311 seconds (75.47% PHP - 24.53% MySQL) with 10 queries
