Hi
I have finished one of my Aleph2 Mono. However, I got a 60 mv DC at the speaker jack without signal connected. Is it troubled or can be used. I also checked the service manual of Aleph 2, the specification of DC offset mentioned <100mv. I don't quite understand the same things or not. After 90 mins, I measured a 55° C (heat sink) under room temperature 25° C. The basis was adjusted 0.55A per Mosfet. Please advise.
#2 | |
service manual. Just curious, did you measure this amount when the amp was hot or cold? I hear it's starting to get hot in HK. I guess you'll have to aircondition to keep the room at 25C... ![]() Cheers, Dennis |
#3 |
Hi LawKa,
I also from Hong Kong. Where did you find the Heat Sink ? Hui, Yes, Hong Kong will go in Summer ! Thomas |
#4 |
Thomas
I bought the chassis from Tai Wan with 4 sides heat sink. Further, I will keep trying to well match the Q1 & Q2 and lowering the bias to maintian the safety temprature <50°C (I guess <0.5A per mosfet). Could anyone reveal the performance of using the CLC filter or CRC filter. Thank you |
#5 |
Banned
Hi lawaka
as some other members have said your offset is normal and is the result of component tolerances and device spreads |
#6 |
Yes,60mV is an acceptable offset value regarding component tolerance
.U should pay much attention to the heatsink temperature.
#7 |
Should I make a cooling fan at the top, useful or not. I also wish to ask the running temperature of original Aleph 2. Anyone can help.
Happy listerning. |
| hybrid amp,split ouput | blondfire | Solid State | 3 | 1st March 2007 11:06 AM |
| Ouput relay vs low end response | d3imlay | Solid State | 3 | 11th December 2006 07:24 AM |
| LM4780 - ouput = 4.4v - PB! HELP! | aceditnanar | Chip Amps | 6 | 3rd July 2006 04:10 PM |
| Amplifier ouput relays | d3imlay | Solid State | 19 | 17th February 2005 01:12 PM |
| Page generated in 0.08599 seconds (76.71% PHP - 23.29% MySQL) with 10 queries |
