Dear all sir:
I'm fixing one pair of Threshold stasis 1 amplifier. Now it's normal working. But I don't know what is the bias adjust standard? I've searched some past thread and show it should set to 0.75A. But which point should I check to 0.75A? Or is any standard method to adjust the bias? Sorry about my poor English.^^ Wish to find some answers. Best Regarded!
#2 |
the ususal place is the fuse of the negative power rail. Remove the fuse and measure the current with your meter connected to the two connections of the fuse. But take care - it takes a long time until the reading gets to a stable status - even if you have removed the top plate of the amplifier housing. Sorry for my bad english too. cheers Michael |
#3 |
Thanks for your reply.
Is any adviced value? Now I set the bias by referance of the heatsink temperature. It's 42 centigrade when stable. |
#4 |
yes i guess - this was the way "np" did it also... Michael |
#5 |
The one and only
That's how I do it.
#6 |
Very thank you Mr.Pass and Michael
![]() I've solved my problem. Now it's singing perfectly!
#7 |
edit ON: this was the way np did it with the old amps and do it today with the new amps... edit OFF: I hope this sounds better than the other statement... |
#8 |
Please, I need help.
Here is the image of a threshold stasis 1 driver board. There are 2 trimpot (those marked as 1 and 2) for bias regulation, one for positive and the other for negative rail. I search the forum and I've found how to set them. But i need to know how to set the 5 others trimpot (those marked 3, 4, 5, 6 and 7). Wish to find some answers. Best regards |
#9 |
The one and only
This appears to be a very early version - I was not aware that
there were any in the field. Unfortunately, I don't have a schematic of this circuit, only the later, very different version. Basically though, you have two amplifiers operating in parallel, something that you can see if you go to the original patent. One amplifier is the voltage amplifier, capable of delivering current directly into the load, and the second is a current bootstrap amplifier, which operates to source current to the load which is a multiple of the current coming from the original amplifier. You can see the separate differential input pairs and the offset and bias adjustments for each in the photo.
#10 | |
The one and only
between the channels. If you think they need adjustment you will need to monitor DC at the output of each amplifier and locate the DC adjustments. Having identified the DC pots, you adjust the remaining for minimal distortion in the amplifier driving a load. If you don't feel confident playing with this, then don't.
| Need help finetuning my Stasis PA-5 | dj.barry.v | Pass Labs | 3 | 16th January 2009 08:19 PM |
| 400A or Stasis 3? | Mywing | Pass Labs | 6 | 4th November 2007 06:53 PM |
| Stasis One Meter | bagigios | Pass Labs | 0 | 22nd December 2006 02:37 PM |
| Stasis Amp | lumanauw | Pass Labs | 9 | 24th April 2005 08:44 AM |
| Threshold Stasis 3, too | Roscor61 | Pass Labs | 3 | 20th May 2004 09:12 AM |
| Page generated in 0.10096 seconds (81.70% PHP - 18.30% MySQL) with 11 queries |
