diyAudio Moderator Emeritus
In some Threshold amp, I found configuration like this for A42. Base and collector are tied together, but the emitors are more positive than the base/collector.
What is the name of using this transistor like this? How many mA will pass in this configuration? |
#2 |
Hi, Walter Burkhart
Indeed it makes a dioda if the collector/base is more positive than the emitor. But in here, the emitors are more positive, like inversed diode. What happened to a transistor treated this way? |
#3 |
The one and only
It's a zener diode, at about 7 volts, which is a typical
E-B breakdown voltage. Check to make sure though, as some bipolar fab processes yield different voltages. |
#4 |
Interesting, but why not use a simple zener?
/Hugo |
#5 |
The one and only
Just to be bad and confuse everybody.
#6 |
No doubt I believe you, you sometimes do have that tendency
Only from a commercial point of view, two transistors are more expensive than a zener. Well, for mass consumer products that would be the consideration. /Hugo |
#7 | |
Does everyone here knows this except me? |
#8 | |
The one and only
of the selection process.
#9 |
The one and only
Something else you might not know is that the typical
bipolar transistor works backward (exhange C for E) but not a rated voltage - The BE breakdown voltage is the limit. |
#10 |
That pretty much answers the question in post #2.
But what are A42's? I did find 2SA42 but that's an old germanium...and PNP /Hugo |
| Threshold SA 1 | reinhard | Pass Labs | 9 | 13th December 2010 04:16 PM |
| Threshold SA/12e | Danish | Pass Labs | 16 | 23rd February 2010 02:21 AM |
| Threshold | canzca | Pass Labs | 1 | 4th May 2008 11:27 PM |
| Threshold! | kekropas | Pass Labs | 11 | 8th April 2005 07:18 PM |
| Page generated in 0.10753 seconds (77.89% PHP - 22.11% MySQL) with 11 queries |
