#11 | |
be patient I had an idea and drawn this circuit. It is based a little on answers and publications from Mr.Pass and publications from Mr.Borbely in Audio Electronics (The new frontiers-> Basis knowledge to JFETs) . I mailed this to Mr.Pass with ask for publishing-permission (Thank you Mr.Pass). He answered Passlabs use only a single set of secondary mosfets, so I have simplified this. External components are not drawn. Actually schematic coming soon. (I play at present a little with the values) Please excuse my very poor english. Best wishes Adam |
#12 |
Did you draw the schematic this way in order to explicitely show an "X"?
PS: your english is ganz gut
Just remember: in theory there's no difference between theory and practice. But in practice it usually is quite a bit difference... Bob Pease |
#13 | |
I like "X" In the figure of feedback (next update) is this so simply to draw. /Adam |
#14 |
...as I also had Pass (Zen V5 for the second stage and the Susy patent for input) and some Borbely articles in mind for this....
NB-Don't rely on the values, and I think that some compensation caps would be needed. It's just the topology I want to show...don't know if it will work, still buying (=looking for ) the components...Later, Tino |
#15 |
.....I thought this would be the natural evolution of the circuit above
But now you overtook me in posting the schematic, and yours seems to be quite more refined... Am I wrong or can I see some John Curl elements in the input stage? Well, I attach my proposal of the balanced thing.... Ciao, Tino |
#16 | |
adam |
#17 |
Outstanding work gentlemen. Thank you for posting. This looks like it could turn into a great thread.
ACAUDIO: It looks like your schematic has twice as many MOSFETS as the PCB. Is this what you meant by "Passlabs use only a single set of secondary mosfets"? GL |
#18 |
Shouldn't the JFETs be cascoded - I thought I read this in a post from Nelson Pass (would also similar to the Borbely design) ?
Martin Rupp |
#19 | |
I was "dreaming" of stuffing the non balanced circuit on a very compact PCB without input and feedback resistors, just as an op amp replacement.... But this balanced thing is also quite interesting. Nelson mentioned not too long ago, that the susy principle will work best with low feedback ratios. What is low? < 20dB, or even less? I believe that my circuits will have at least 60dB open loop gain (don't know yet), so for 10 dB gain we have a loop gain of 50 dB. Too much? Well, I'll have to go sleep now... |
#20 | |
Oh, yes, if we would like higher rails, then cascoding is a must. J-fets cannot take high voltage around them. But now, definitly.....Buona Notte. |
| Page generated in 0.11347 seconds (81.05% PHP - 18.95% MySQL) with 10 queries |
