I'm building a Zen out of pieces i found in my junk box.
Using a BOZ with IRFZ44 for PreAmp and then a modified Zen v4 using IRFP450's. On the bench I tried it with a regulated PSU 32V DC/ 7A per chanel and got quite a bit of hum. It seems to be the PreAmp that induces the hum because when I use a seperate PSU for the BOZ's, the amp is dead quiet. Ground loops? On hand I have alot of 24V/300VA trannies and 33 000uF/70V caps. Do you think I should use 3 regulated PSU's, one per amp and one for the BOZ's or build an other PSU using the 24V/300VA trannies and caps.? Any one that have experiance of both? The regulated PSU's are from Power One with a 'standard' E-core transformer, 3 x 2N3055 driven by a uA723.
The probability of someone watching you is proportional to the stupidity of your action. - A. Kindsvater |
#2 |
'Close up' of the BOZ and ZEN AMP card with interconnections.
#3 |
Made the casing today, so its time to put the amp together.smash:
Is there no one that has a comment on if I should go with the pre made regulated 32V PSU-units or build an unregulated 35V one ?? Any sugestions would be apriciated!
| My DIY UcD amp from the junk box | acid_k2 | Class D | 28 | 25th October 2011 12:32 PM |
| JYD (junk yard dog) | cnctooltek | Multi-Way | 10 | 18th October 2006 04:50 PM |
| New Chip Junk | classd4sure | Class D | 85 | 20th September 2006 09:24 PM |
| Just got new junk from my friend | Giaime | Solid State | 29 | 22nd March 2005 01:29 PM |
| got some interesting junk | yosh | Parts | 2 | 27th June 2004 10:01 AM |
| Page generated in 0.07474 seconds (74.15% PHP - 25.85% MySQL) with 11 queries |
