A Question about SuSy and the X2
Old 30th March 2005, 12:37 AM   #1
metalman is offline metalman  Canada
metalman's Avatar
Default A Question about SuSy and the X2
Quote from the 1998 article Super Symmetric Amplification by Nelson Pass
Su-Sy is an approach that takes advantage of balanced operation like no other design and requires a balanced input to retain the precisely matched behaviour. You can drive one input alone, and the circuit will amplify reasonably well, but it will not exhibit the very low distortion character of fully balanced operation.
Rev's 0 & 1 do not appear to use X-feedback, but assuming that the O and I of the UGS modules from Rev's 2 & 3 stand for Output and Input, it would appear that X-feedback is being used on the output gain stage. However, as the balanced inputs are converted to single-ended before being fed to the output stage, the quoted passage infers that the benefits of Supersymmetry will be negated. Am I interpreting this correctly, or am I being fooled by the mystery internals of the UGS?
My main motivation in asking this is to determine if my substantial effort to produce a fully balanced stereo stepped attentuator, and convoluted input/output switching arrangement for my CC-CCS-X-BZLS could have been avoided.
Care to comment Nelson?
Old 30th March 2005, 01:51 AM   #2
thomasfw is offline thomasfw  Hong Kong
Mr Nelson,
My head is burning with same question !!!
Please tell us some information !
Thomas
Old 30th March 2005, 06:16 PM   #3
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
Default Re: A Question about SuSy and the X2
The earlier X2 circuits use very little X feedback, but it is there.
The UGS module, like all the later circuits, is perfectly happy
being driven single-ended. It just takes the difference between
the driven input and the grounded input.
The initial SuSy circuits of the X600 and X1000 required balanced
inputs for best operation, but we were able to remove that
restriction in subsequent product.
Old 31st March 2005, 12:44 PM   #4
Darry is offline Darry  France
Hello M. Pass
Is It possible of driver X600 in single-end with this adaptor?
ADAPTOR, XLR PLUG/PHONO JACK; Connector type A:XLR Male; Connector type B:Phono Jack
Thanks for the answer
Darry
Old 31st March 2005, 09:25 PM   #5
The one and only
Yes, but I beleive it simply allows you to connect the RCA
hot to input pin 2 of the XLR, and does not give balanced
performance.
You can drive the 600 and 1000 with single-ended inputs,
but they develop greater 2nd harmonic (and other) distortion.
Old 1st April 2005, 04:55 AM   #6
jh6you is offline jh6you
Account Disabled
Default Re: Re: A Question about SuSy and the X2
Now I see there is a little X-feedback. And, I see that the Earth is round. I did not know that, when I play golf, actually I play with two balls: one small and one biggg. Yes, I should hit the small ball first and then hit the biggg ball. I do opposite way sometimes.
A Question about SuSy and the X2Hide this!Advertise here!
Four for SuSy? Onvinyl Pass Labs 24 24th July 2005 05:56 PM
SUSY simulation test vossie Pass Labs 5 11th November 2004 06:34 AM
Complimentary-symmetry SUSY? vossie Pass Labs 19 16th February 2004 07:01 AM
Copyright ©1999-2017 diyAudio
