#11 |
yes
een ooievaar is geen konijn want zijn oren zijn te klein! |
#12 |
Is there a thread with a definative schema for an upgraded BOSOZ? There seem to be several versions with different mods around on the forum.
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#13 |
I don´t think there´s a definite version cause everybody build it a bit different. I made one without CCS and plus and minus 60V supply and another one with CCS and +40V -20V supply. Some use bjt´s for the current source others use fets. Some have 20mA bias, others up to 50mA. Since the circuit is so simple and doesn´t use many (expensive)parts it is easy to build a few variations. The only thing you have to think of beforehand is if you want to try it without CCS. If so you´ll need a symmetrical power supply with at least +-30V. A current source is always possible although with higher losses in case of a symmetrical supply. What seems to be true for all those variations is that they sound very good without using all sorts of fancy caps and resistors. William
#14 |
Kari is working on a X-CCS-BosoZ layout.
Heatsinks for Bosoz? Can't wait to get some of those boards Steen
#15 | |
Account Disabled
Two CCS tails. 30mA bias. No X-feedback. I am staying hear with full satisfaction of the sound. So far, I do not see any motivation for further mods. Regards |
#16 | |
That seems to be the general problem and that´s why there won´t be a definitive version....... William
#17 |
So I like the one from "Metalman" (Terry)
CS_CSS_X_BOSOZ Thomas |
#18 |
I think the big advantege of the schematic from the first post of this thread is lack of the input cap.
The circuit kind of remind me Aleph P 1.0, that I like soniclly very, very much. I think this might be just a better version of it - IRF610 instead of IRF244 and negative CCS that allows to use no cap at the input. Bartek |
#19 |
Banned
I bet the aleph P1.7 is better right ? Since i have one already i guss i should just finnish that instead : O )
And change all the caps to nicer one's. |
#20 |
| FS:PASS X2 preamp | rubydac | Swap Meet | 3 | 12th May 2008 06:18 AM |
| FS: Pass Labs X2 preamp | Studley | Swap Meet | 0 | 18th January 2007 10:53 PM |
| Preamp for Pass Aleph 0s? | Vermeer | Pass Labs | 5 | 20th October 2004 11:46 PM |
| Pass DIY preamp PCB? | illenema | Pass Labs | 2 | 28th January 2004 08:59 PM |
| Which pass preamp? | gregjpeters | Pass Labs | 7 | 20th November 2002 05:48 PM |
