Nelson or if anyone else knows the answer, two of my freinds were arguing about the class of the Pass X or the XA series of power amps.
One was positive that they were push/pull the other was positive that they are single/ended. The single/ended guy said it looks like push/pull but it's not, the bottom transistors are constant current sources for the top ones, not having seen the circuit i could'nt correct either one of them, so does anyone know? So i can declare a winner. Cheers George |
#2 |
The X series is balanced push-pull.
The XA series is balanced single ended, but with a current controled current source instead of a ccs. Uli
![]() 'Jazz is not dead, it just smells funny' F.Zappa |
#3 |
I ask the "Local Agent", the answer is :
X : will be discontinued soon XA.5 : Class AB XA : Class A I think only Mr Nelson Pass can tell us the true answer ! Thomas |
#4 | ||
X.5-Series is Class AB but SE Class A to a higher power than X Quote:
This info can be easily distilled from NP´s info on www.passlabs.com Uli
#5 |
The one and only
The current X amps are becoming ".5" amps, which is the
same model # and specs but with some tweaks in the power supply, gain stage, and output stage. The most discussable change is the small amount of single-ended bias applied to the output stage, which makes each 1/2 of the amplifier operated SE Class A for a couple watts. The XA amps are staying the way they are for the time being, and the introduction of the XA60 looms near. As I have said before the phrase "balanced single-ended Class A" is an oxymoron thought of by someone else but aptly describing the result of balancing two SE circuits. The result is 3rd harmonic, not 2nd due to the cancellation of the 2nd harmonic, but we find that you get a better result when you start with SE circuits than when you start with PP circuits. Apparently the character of PP circuits which are then balanced shows the compounding of two 3rd order characters, and balancing SE circuits sounds better (IMHO).
#6 |
Nelson,
I have a question on the X2 service manual you recently released at PassLabs. In your articles on supersymmetry you imply that a supersymmetric circuit when driven single ended shows no advantage over the equivalent circuit without supersymmetry. But in the X2, the balanced signal is converted to single ended before it is delivered to the gain stage. Doesn't this arrangement cancel the benefit of the supersymmetric feedback in the gain stage, or is there something inside the mysterious UGS modules that still makes the supersymmetry beneficial? I've been trying to wrap my head around this and have only succeeded in turning circles Cheers, Terry |
#7 |
Dear Nelson,
I have an idea... Could it be possible to make some sort of a SE folower output stage .?.. based on a active current source like in the Aleph.. This change a X-serie amplifier with a PP output stage to a SE with minimum modification ? regards, Thijs |
#8 |
Dear Nelson,
I have same question what the Terry asked when I studied the X2. Would you please explain more detail about this issue !!! Best Regards ! Thomas |
#9 | |
Well , I do not see the feedback in the schematics of the X2 version 1 , Supersymmetry is essentially the symmetric feedback around the differential pair . So I believe that SUSY is not applied in the first X2 . |
#10 | |
| Series Pass Transistor for TL-783 | sonata149 | Tubes / Valves | 9 | 6th February 2009 12:06 PM |
| request for pass x series's schematics | lanyuflying | Pass Labs | 5 | 24th January 2009 05:05 AM |
| Pass Labs X-Series | dejanm | Pass Labs | 12 | 5th December 2006 05:52 AM |
| pass aleph series overview? | Oil | Pass Labs | 3 | 28th August 2004 12:54 PM |
| About replicating a Pass X series amplifier | Musher | Pass Labs | 58 | 14th February 2002 01:34 AM |
| Page generated in 0.11896 seconds (78.66% PHP - 21.34% MySQL) with 10 queries |
