Old 22nd March 2005, 06:58 AM   #1
EANDERS is offline EANDERS  United States
Question bosoz rail voltages
first post so bear with me please.
Just finished one psu board for xbosoz. The neg rail is at 60vdc.
The pos rail is at 53.7vdc?
pos drain is 95.5vdc, gate is 63.3vdc.
neg drain is 95.7vdc, gate is 63.5vdc.
checked the zener chains - ok, z115 is ok, c105 is ok.
replaced the irf610 mosfet on the pos side, still the same.
question, should the loss be greater thru the 610 vs the 9610?
or am i missing something obvious.
also note no difference loaded with 15k or open.
can i just add a proper value zener to the chain to obtain the voltage
i want?
Thanks, eanders
Old 25th March 2005, 06:53 AM   #2
Uh, nevermind,
installed the 610 backwards inverting the source and gate.
now all is good.
the good news:
1 I laid out the point to point on paper correctly.
2 I got the drain in the right hole.
the bad news:
1 I can't follow my own drawing.
Humble Pie is a great rock group, that's my story and I'm sticking to it!
Thanks, eanders
Old 25th March 2005, 04:19 PM   #3
Ren is offline Ren  United States
You are sentenced to:
30 Days in the Hole
modern day rail voltages Clipped Car Audio 3 28th September 2007 04:38 AM
Rail voltages from 15-0-15 volt transformer Bama Slamma Power Supplies 3 26th November 2006 10:27 AM
the best transformer rail voltages for gainclone? araven Chip Amps 2 30th September 2006 10:31 PM
Amp supply rail voltages.... Xicarius Everything Else 2 4th August 2004 12:38 AM
help with rail voltages Svetlana Pass Labs 11 24th June 2004 09:35 PM
Page generated in 0.06610 seconds (68.80% PHP - 31.20% MySQL) with 10 queries
