This is what it takes to build A75.
For more pictures check http://www.diyaudio.com/forums/showt...2954#post52954
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#2 |
What's with the zip ties?
#3 |
I was under the impression that if I pull the caps together I might eliminate their susceptibility to vibrations and microphonics.
#4 |
I have always wondered what are the purpose of the ties around the capacitors. I have seen big can capacitors with metal strap around them. What is the real purpose for doing that?
#5 |
Metal strap at the bottom of the cap is used to screw the cap to the chassis. It's just a way to mount it.
#6 |
I meant metal straps that are installed half way up the capacitors .... just like what you did but it's metal strap. I believe I have seen Krell & Threshold amp doing that. Metal strap around the 4 big can capacitors.
#7 |
One can only hope those strps were not magnetic. It's not coincidence I chose plastic wraps.
#8 |
I recently wondered if it would be a good idea to use capacitor with different size to prevent resonant coupling between them. Sort of what they do in the oil storage tanks. Maybe one could group a different number of caps with the same size to get the same effect. Also, wouldn't it make sense to reduce the cap size as much as possible to bring the first fundamental resonance out of the audio range? Echoes would have much lower intensity and would be less of a problem. I heard caps in AC coupled amps resonate and that wasn't pretty. I found it tends to cause loss of focus in the sound. |
#9 |
In the picture, are we looking at 2 discrete audio channels?
Are you using 24 ea TO-3 devices for one channel? Nice milling. Aud_Mot |
#10 |
Two monoblocks, 24 devices per channel, separate active regulation for active stage.
Milling was the only elegant option with TO-3 devices and my sinks. The whole thing can be seen here: http://www.passdiy.com/gallery/a75-p7.htm
| PS Audio 200 CX Revisited | Don S | Solid State | 48 | 9th April 2012 12:59 PM |
| Goldring GR 1.2 revisited? | Sella | Analogue Source | 5 | 2nd April 2012 12:28 AM |
| IV conversion (revisited) | Zoran | Digital Source | 27 | 30th November 2005 06:08 AM |
| Revisited Zen | seve | Pass Labs | 6 | 16th June 2004 09:41 PM |
| Page generated in 0.10645 seconds (74.16% PHP - 25.84% MySQL) with 11 queries |
