Can the Pass amp current sources be replaced with something like the LM133?
Or is there an advantage to the discrete current sources? Just curious. vinay |
#2 |
??? Only "LM133" I can find is Landmark's Very High Brightness LCD Module. I don't know if it can be a current-source, but that sure is the expensive way to do the job. Did you type "LM334" and line-noise corrupted your bytes? > Or is there an advantage to the discrete current sources? The LM334 is a 3-stage BJT amplifier, probably not as hyper-linear as we might like in fine audio. Dumb current sources have simple inoffensive flaws. I have no clue which of the many "Pass amps" you are pointing at, but the LM334 is only good for milli-Amps and I know Nelson has some designs that suck many-Amps. At that level, the LM317 volt-reg strapped as a current-regulator is popular. This thing has about 6 active stages with 26 total transistors: not at all the simple thing it appears to be. Sure you can adapt different current-source techniques and technologies. What you get may not be quite the same as the original. Putting these many-stage chips in place of a dumb FET may give you better numbers and worse sound. Or may not. |
| Pass Son of Zen w/current sources (etc.) | GRollins | Pass Labs | 87 | 15th May 2006 05:35 PM |
| constant current sources... | cathode_leak | Tubes / Valves | 10 | 29th March 2005 10:18 PM |
| Op Amp based current sources | Kevinbd | Solid State | 1 | 3rd October 2004 07:18 AM |
| Aleph P current sources? | stefan | Pass Labs | 12 | 20th August 2002 08:01 AM |
| Current sources (not sinks) | dlharmon | Pass Labs | 1 | 6th February 2002 10:36 PM |
| Page generated in 0.07218 seconds (72.59% PHP - 27.41% MySQL) with 10 queries |
