The Aleph30 PCB layout
Old 28th February 2006, 10:37 PM   #271
KevinTams is offline KevinTams  United Kingdom
Default hot hot HOT
I thought my amp was very hot. I've never had an amp run this hot before and was a bit nervous so........ I borrowed a few thermistors from work and fastened them onto various components inside and outside the amp, closed it up and played it for 2 hours.
The top of the IRFP240's got as high as 67C, the tab of a 9610 on the differential pair got to 82C, ambient inside the amp was 48C, temp on the hottest spot of the heatsink was 55C.
These readings surprised me as I can barely hold the palm of my hand against the heatsink for more than a few seconds yet the temp on the 240 suggests my heatsinking is OK.
Question: is the tab temp on the 9610 a little high at 82C as the spec says absolute max is 150C at the junction.
BTW fantastic sounding amp
Kev
Old 28th February 2006, 11:35 PM   #272
Mark A. Gulbrandsen is offline Mark A. Gulbrandsen
The boards arrived while I was up in Montana. They look excellent... Great job Peter!
Mark
KSA-100 WIKI
Old 1st March 2006, 02:54 PM   #273
wilbur-x is offline wilbur-x  Tibet
Ultrafast cross atlantic delivery , nice boards indeed.
Peter is the man.
Is there any parts list available to clone ?
Old 1st March 2006, 06:13 PM   #274
Attached is a BoM I used when making mine, it should be fairly obvious.
Kev
Old 1st March 2006, 08:09 PM   #275
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Default Re: hot hot HOT
Kev
just place one mutual heatsink for both 9610.....even Alu plate is good enough
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 1st March 2006, 09:25 PM   #276
Mad_K is offline Mad_K  Norway
Mad_K's Avatar
Kev
No problem. Keep the junction below 100'C and your're in good shape.
Q1/Q2 junction temp: 82'C + (0,3W x 6,4'C/W) = 84'C
Mads K
Old 2nd March 2006, 11:58 PM   #277
Stupid question from me to all of you so I don't have to go back thorugh all the posts to find out but what type of 1/4 watt resistors this board laid out for? I have yet to use these little doggies yet and am curious.....
Thanks!
Mark
KSA-100 WIKI
Old 3rd March 2006, 12:46 AM   #278
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
The Aleph30 PCB layout Send a message via AIM to Peter Daniel
Those are Phoenix SFR16S type: http://dkc3.digikey.com/PDF/T061/1218.pdf
or Caddocks MK132
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 3rd March 2006, 01:05 AM   #279
Thanks Peter.,
That should be the last of my stupid questions....
Mark
KSA-100 WIKI
Old 3rd March 2006, 01:26 AM   #280
The stuffing info was posted here: http://www.diyaudio.com/forums/showt...068#post617068
www.audiosector.com
The Aleph30 PCB layoutHide this!Advertise here!
Eagle vs. Sprint-Layout for PCB design/layout hollowman Parts 11 12th January 2014 09:01 PM
