Aleph 5 with no (few) gain
Old 12th March 2005, 05:29 PM   #1
ElectroNick is offline ElectroNick  Netherlands
ElectroNick's Avatar
Question Aleph 5 with no (few) gain
The past week i've been testing the A5 amp. One channel gives 16 mV at output at works fine.
But.... the other one seems to have no gain. While inspecting both channels i found that at the base of Q5 (T4 in the Kristian schematic) there was a lot of noise on the signal. The signal itself is not amplified, in the other, good mono section you can see a larger signal.
The only thing i recall the past week, while switching between both channels., i heard some "spikes" while connecting the speaker to the bad amp.
So far i changed C10 and Q5 (T4 and C3 in the Kristian schematic)
What can it be, i'm getting confused. Am i looking in the wrong place, i mean is some other component responsible for the trash signal on the base of Q5 ?
Old 12th March 2005, 07:45 PM   #2
Phill is offline Phill  Mali
hello
I am sorry to be able to answer your question ...
I visited your Web page ...
can you explain this image
which are the components used?
thank you
Phill
Old 12th March 2005, 08:58 PM   #3
Netlist is offline Netlist  Belgium
diyAudio Moderator Emeritus
Netlist's Avatar
Does the diff pair work?
What DC values do you get at the crucial points? VCE Q5, voltage over R14, is there bias current flowing trough the outputs?
/Hugo
Old 13th March 2005, 01:41 PM   #4
I found the error
It seems that i drilled through a trace when i was placing the three capacitors, they had a different size.
I soldered the caps but overlooked the missing trace
Anyway : a simple repair on the PCB and the Aleph was working.
I'm now building it together again and in an hour or so i'll sit back and relax (maybe with some wine )
Grtz
Nick
ps : @ Phil
It's a simple discrete rectifier with MBR1645 and some MKS caps.
ps2 : i'm not using this bridge at the moment, for now only a "simple" metall rectifier bridge.
Old 13th March 2005, 02:08 PM   #5
Netlist's Avatar
/Hugo
Aleph 5 with no (few) gainHide this!Advertise here!
Aleph P1.7 Gain Bengali Pass Labs 1 19th November 2008 04:28 AM
Gain Aleph 3 and Aleph L?? Nelson? Metric Pass Labs 1 10th April 2006 08:13 PM
Aleph 30 gain Freddie Pass Labs 9 11th May 2002 04:02 AM
Aleph gain Koy Pass Labs 1 30th January 2002 11:55 AM
