diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Pass Labs (http://www.diyaudio.com/forums/pass-labs/)
-   -   Threshold 4000 "polarity" (http://www.diyaudio.com/forums/pass-labs/53206-threshold-4000-polarity.html)
inertial 10th March 2005 11:52 AM
(sorry for my english)
I have two simply questions:
1) Was it inverting or not-inverting? (I haven't owner's manual)
2) I think it's time to replace the four original big capacitors: what is the minimum possible value for each ? ( numbers are illegible)
Thanks advanced for your time
P.S.: after 25 years( or more?) the amp is "perfect".
Nelson Pass 10th March 2005 06:39 PM
All the Threshold and Pass Labs amps/preamps are non-inverting.
Try 15,000 uF minimum at 75 volts. The big thing is to fit the
can in the same diameter bracket with similar height.
inertial 11th March 2005 11:10 AM
Thank you very much, Mr. Pass .
You are really "the one and only"!! :)
best regards from Venezia
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
