Old 7th March 2005, 09:39 PM   #1
Raoul is offline Raoul  United States
Default BoSoZ PSU Question
I currently have a BoSoZ powered by one power supply board. The power supply is being fed by two toroids that I purchased from Apex Jr. They are rated at 28.4 volts (dual seondaries) at about 150VA.
I have a second power supply board already built. My question is: would it be beneficial to split each secondary of the transformers into two lines, giving an effective total of 4 secondaries per transformer, and power two seperate power supply boards with one transformer each?
Thanks in advance for any advice.
Old 8th March 2005, 01:01 AM   #2
eLarson is offline eLarson  United States
eLarson's Avatar
It wouldn't hurt your imaging, I reckon.
Would a woodchuck bother to chuck MDF?
Old 8th March 2005, 06:03 AM   #3
Thanks for the reply, eLarson. That's what I was thinking. I think the Avel transformers Nelson used were rated for 60VA total, so I figured that, at 150VA, these had enough juice behind them. I just wanted to make sure I wasn't going to run into some problem I didn't foresee...some of my electronics "expertise" is pretty crude.
Thanks again for the reassurance.
Old 8th March 2005, 01:44 PM   #4
eLarson's Avatar
In terms of the size of the toroids, even 60VA is plenty big for a preamp. It is the isolation of the channels that might help a touch. Whether you hear it will depend on what happens in the amp, the speakers, the room, your ears, your mood. Stuff like that.
Erik
Old 8th March 2005, 02:44 PM   #5
vdi_nenna's Avatar
Send a message via Yahoo to vdi_nenna
I'm working on the same thing right now. How would you wire the transformers and power supply boards? Would the Thermistors tie to the same ground point?
Vince
bosoz question... cowanrg Pass Labs 9 27th November 2004 01:39 AM
BOSOZ with CCS, and a question jh6you Pass Labs 11 26th March 2004 05:25 AM
BOSOZ PS Question vdi_nenna Pass Labs 5 4th August 2003 10:25 PM
Bosoz psu question protos Pass Labs 8 25th November 2002 03:39 PM
BOSOZ question audionut Pass Labs 1 27th July 2002 02:34 PM
Page generated in 0.08639 seconds (74.40% PHP - 25.60% MySQL) with 10 queries
