Hi all.... I am in the process of finishing a Zen V4.
I got both channels running and have the sinks already, so now, I am trying to figure out the chasis lay out and the best way to mount the transistors, since the way they are now are running a little hot I am trying to decide between Kapton, Delta Pads or Sil Pads any coments. Another question... I know that Kapton and Sil Pads are Greasless... how about Delta pads? thanks. |
#2 |
Nelson did a series of tests here:
Mica and Goop Here's a second link: http://www.bcae1.com/heatsink.htm Hope this is of some help Good luck with the Zen. -=Hugo=- |
#3 |
if you can believe the specs the kapton ones have only 0,07°K/W wich makes them the best by far. I´ve used them for my Aleph5 and X without problems. The big advantage is that they already have some grease applied so no messing around with grease all over the place. William
een ooievaar is geen konijn want zijn oren zijn te klein! |
#4 |
thanks guys.... I think I will try a Kapton and silpads... and see the results.
wufwaf: I found some specs on kapton and found the thermal resistance to be 0.4 .... Where did you get 0.07 from? |
#5 |
| Transistor Insulator Sources - US | Zero Cool | Solid State | 21 | 6th May 2008 02:04 AM |
| TO-247 insulator from a TO-3 | JCM | Pass Labs | 11 | 13th April 2006 08:58 PM |
| Stacked Acrylic ESL Insulator | BillH | Planars & Exotics | 31 | 28th March 2006 12:35 AM |
| Magnetic field insulator | GiveMeBoost | Everything Else | 22 | 21st April 2005 06:12 AM |
| is this really a TO-5 insulator? | travis | Chip Amps | 10 | 6th July 2003 01:12 PM |
| Page generated in 0.08424 seconds (71.26% PHP - 28.74% MySQL) with 10 queries |
