dear nelson,
i want to make 5 watts zen amplifier using irf510,since i have excess irf510's in my stock.can you tell me what all changes i have to make in the circuits.i have one good quality 24v/4A transformer with me.with these two things can i make baby zen renjish |
#2 |
The one and only
Funny you should mention, I just built something like that
a couple weeks ago. 18 VAC secondary feeding a CRC (cap resistor cap) filtered supply at about 23 volts, and what looks like the original Zen circuit but with the 610 (510 will work just as well) on the bottom and a 9610 P channel or 610 N channel current source, and about a 1.2 amp bias. The feedback network has much higher values (lower capacitance on the Mosfet so it has a higher impedance) and the distortion is a little higher than the original Zen, but it sounds good on compression drivers. Clipping starts at about 4 watts rms, 8 watts peak. It's a little anemic compared to the Zen, but the top end is better extended, and its much kinder to source impedances. I've worked up a version without feedback which has a .5 to 1 ohm resistor on the Source of the gain device, and it makes a nice current source amp as well. If you have a Lowther or Fostex, it would give you a chance to play in that sandbox. If one of the locals here doesn't work you up a schematic, it or something like it will show up on www.passdiy.com in a couple months. The key thing is a well filtered supply - you don't want the noise figure to compete with 4 watts.
#3 |
Location: kansas city mo, and on occasion, around the world ...
ben duncans amp-02 project showed truly advanced thinking
about noise in power supplys, yet i haven't seen any one utilize such in diy(except for the amp-02) |
#4 |
dear nelson
yesterday night i made this circuit and tested it,but without speakers.it was taking 1 amp bias current .power supply is not properly regulated.today i will test it with speakers. what is your opinion about this circuit.please comment |
#5 | |
The one and only
(npn in your case) bipolar transistor to sense the voltage across the Source power resistor, setting it at about .65 V. This is not as simple as your circuit, but gives better regulation. You can see it in the later Zen circuits. After that, it looks like Bob's Your Uncle. Remember that this circuit likes a low an impedance as seen by the Gate of the gain Mosfet, so you try to keep the source and feedback impedances as low as possible. Also, if you tend to bias the gain device at a higher D-S voltage you will get lower distortion at high frequencies, so add a couple volts to the DC output voltage, and it will sound a bit better. And.... this wattage on an IRF510 is pushing it, so be prepared to heat sink this well, or lower the current, or get a bigger transistor.
#6 |
Dear Nelson
Thank you for giving me such a nice advice Yesterday I connected it to my speakers, the sound quality was very good especially mid and high’s, but there is lacking of bass and the volume is also very low. So I removed the feedback, volume increased little more. Today I will try to do what you have told me. I will change the BJT to MOSFET as current source. But I don’t want to change the IRF510’s, since I have some pieces in stock. Regards renjish |
#7 |
Banned
dear nelson
yesterday night i made this circuit and tested it,but without speakers.it was taking 1 amp bias current .power supply is not properly regulated.today i will test it with speakers. what is your opinion about this circuit.please comment -------------------------------------------------------- class A!!!!!!! |
#8 |
I was reminded of this "Baby SOZ" reading this thread.
http://www.passdiy.com/gallery/soz-p7.htm They had a nice write up about the amp, but unfortunately their provided link is dead now... I did some searching, and dug up the page using the Internet Archive Wayback Machine. Check out this link for a what was archived if you're interested. http://web.archive.org/web/200301050...la+anatomy.htm |
| My new baby amp | suzyj | Solid State | 21 | 19th May 2009 02:11 PM |
| My new baby | GrahamnDodder | Chip Amps | 42 | 18th October 2003 02:49 AM |
| My baby is HOT!! | jazzy | Pass Labs | 18 | 9th June 2003 09:37 AM |
| Page generated in 0.10512 seconds (79.55% PHP - 20.45% MySQL) with 11 queries |
