Aleph P current sources?
Old 14th August 2002, 08:46 AM   #1
stefan is offline stefan
stefan's Avatar
Send a message via ICQ to stefan
Question Aleph P current sources?
Hi all,
Can I use in Aleph P current sources with
bipolar transistors (i have a lot of them)?
Will this change the sound performance?
Old 14th August 2002, 01:48 PM   #2
wuffwaff is offline wuffwaff  Netherlands
wuffwaff's Avatar
Hi Stefan,
yes you can. Wouldn´t know why not. As for sound differences it´s not so difficult to try both isn´t it.
I assume you´ll have to buy more fets than you need anyway
william
een ooievaar is geen konijn want zijn oren zijn te klein!
Old 15th August 2002, 08:47 PM   #3
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
For all I know they will sound better.
Old 16th August 2002, 08:46 AM   #4
stefan's Avatar
Thanks, mr. Pass!
I'll try and if all is OK I'll post schematics here.
Old 16th August 2002, 10:30 PM   #5
stefan's Avatar
Default Simplified schematic - how will work?
Here is simplified schematics for Aleph P
with bipolar current sources.
I still didn't made it and I need your opinions.
Do you think this will work well?
Old 17th August 2002, 09:50 PM   #6
The one and only
Your input source is going to see some DC, so you might
consider caps for that. Also, some nice caps across the
Zeners will take out some noise. Maybe a few hundred
ohms in series with the transistor bases to keep them
from loading down the reference when they saturate.
Old 17th August 2002, 10:04 PM   #7
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
Aleph P current sources? Send a message via AIM to Peter Daniel
How would it affects the circuit if feedback resistors R11 and R14 would be removed? I mean, is there a way to get rid off the input coupling caps?
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 19th August 2002, 06:50 AM   #8
stefan's Avatar
I think that it's too dificult to make in this circuit.
In all cases input capacitors are simplest and safest way.
Old 19th August 2002, 06:58 AM   #9
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
I would try connecting R11 *after* C2, and R14 *after* C3. That would give you AC feedback only, but I would expect the circuit to auto-equillibrate with the input gates drifting to ground. Mr. Pass?
Jan Didden
Old 19th August 2002, 08:03 PM   #10
The one and only
The Gates have to be held at a positive potential or
the gain Mosfets will shut down, so some kind of DC
bias for them is required, or use a negative supply
rail instead of ground for your negative current
sources.
Aleph P current sources?Hide this!Advertise here!
Pass Son of Zen w/current sources (etc.) GRollins Pass Labs 89 18th September 2012 02:45 PM
Current Sources vinay Pass Labs 1 19th March 2005 04:23 AM
Aleph+Constant current sources X-ZEN stefanobilliani Pass Labs 46 18th January 2005 02:53 AM
Op Amp based current sources Kevinbd Solid State 1 3rd October 2004 07:18 AM
Current sources (not sinks) dlharmon Pass Labs 1 6th February 2002 10:36 PM
Copyright ©1999-2017 diyAudio
