Old 9th December 2006, 10:11 AM   #911
Originally posted by applebook
Yep, I purchased a pair. Shipping is cheap too. Thanks again.
Just curious, how much was shipping for a pair?
Dennis
Old 10th December 2006, 09:40 AM   #912
Hi, Dennis, shipping is $16 for a 12" x 5 3/8" piece.
Old 10th December 2006, 10:00 AM   #913
yoke is offline yoke  Croatia
yoke's Avatar
Hi ...
I have two questions ;
- how do you connect unbalanced signal to input ? do I need to short ground to - ( of XLR ) ( place jumper from SG to -In )
- and is there way to optimize Aleph Mini for 10W on 4 Ohm ( I need mini to drive 4 ohm tweeter ( scan speak 2904/7000 )
Old 10th December 2006, 04:12 PM   #914
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
Originally posted by yoke
Hi ...
See Picture
And with the min alephs the best thing about them is you can just change heatsink / psu voltage up / down to get more less power.
if you want 10watts id do about 15-Volt rails. Transformer before recitification is about 12-0-12 They sell them on ebay for about 32$
Old 10th December 2006, 04:44 PM   #915
yoke's Avatar
Thanks Jason for replay
I have Aleph Power and Dissipation Spreadsheet from wuffwaff and when I enter 15V or 18V ( small diference in power at 4 Ohm ) I get around 8W ...
The picture below show 15V and 1A ...
From the sime spreadsheet, if I would like more power at 4 Ohm I would nead to rise bias ...
Is this right ? ...
what is the minimum recomended voltage for IRFP044 operation ?
my heatsink could only take up to 18-19W ... so if I would rise bias I would nead to lover voltage to stay inside those 18-19W
Old 10th December 2006, 06:19 PM   #916
Banned
I once had my alephs running at 9V Rail's It worked ok.
Old 13th December 2006, 02:59 AM   #917
I have another question, will this EI 15W 80Ma transformer work? http://www.rpelectronics.com/English...ems/125ESE.asp
I've seen another builder make his/her Mini with those exact specs but want to be sure.
Toroid transformers are ideal with audiophiles, but Antek is taking ridiculously long and is asking for an additional $16 shipping even though I've already paid $25 for shipping (as per their original request).
Old 13th December 2006, 03:05 AM   #918
hayenc is offline hayenc  United States
hayenc's Avatar
Send a message via Yahoo to hayenc
Might doublecheck your link. It brings up an output transformer for a tube amp.
Old 13th December 2006, 03:24 AM   #919
You're right. Here's the correct one: http://www.rpelectronics.com/English...ems/166R12.asp
Old 13th December 2006, 03:53 AM   #920
Is this right ? ...
Hello Yoke,
As Jason mentioned, the best thing will be if you can
use larger heatsinks. (Perhaps use a fan?)
However, if you can only to dissipate 18W per
mosfet then I would perhaps try
12V @ 1.5A. Mr. Pass' mosfet testing article
( http://passdiy.com/pdf/mos.pdf ) shows that the
distortion goes up with decreasing
voltage and goes down with increasing bias.
Then there's the matter of the circuit itself. IIRC,
the biasing circuit of the front end differential
pair will stop working below a certain voltage.
You're right about connecting an unbalanced
signal. Simply short the negative connection
of the XLR to ground and you're all set.
Dennis
mini-aleph versus aleph-3 rmgvs Pass Labs 7 4th February 2010 03:18 PM
Mini Aleph Board & Aleph 2 Parts List gpsmithii Pass Labs 3 16th January 2010 03:58 AM
Aleph Mini / Aleph 3 PCB ready (?) croccodillo Pass Labs 5 27th July 2009 01:51 PM
Difference between Aleph J and Aleph J Mini ppmmcc Pass Labs 5 17th May 2008 06:10 PM
WTB: Aleph-mini PCBs and transistor set for Aleph 30 needtubes Swap Meet 4 6th November 2005 06:29 PM
Copyright ©1999-2013 diyAudio
