New Aleph Mini PCB GB - Page 80 - diyAudio
Old 26th October 2005, 05:48 PM   #791
troystg is offline troystg  United States
troystg's Avatar
Jason's
.... Waiting 60 seconds...................
EDIT:
While waiting it stuck me what the 1/4 watt resistors were also and there should be three of them on my output boards instead!!
Well I guess those were not in the 2 kits I ordered either...
I guess my naivety got the best of me here.... I NEVER contemplated incomplete kits! Ok one cap no biggie... But now we're talking 2 caps and 12 resistors per kit x 2 kits. Now I see why I have been scratching my head.
Edit 2: Atrocious spelling.
Troy
Thinking positive doesn't make things better, it makes you a better person.
Old 27th October 2005, 05:23 AM   #792
steenoe is offline steenoe  Denmark
steenoe's Avatar
Cheer up, mate.
Don't be too hard on yourself, Troy. It is actually a bit confusing with all those different varieties on the same board Just take a look at the A-X boards ver 1.0 It would be a lot easier if it was like; one PCB, one BOM, one amp
Steen
Old 27th October 2005, 12:57 PM   #793
mpmarino's Avatar
Originally posted by Tweeker
Is this the zener that is recommended to be bypassed by 1-4.7uF as a mod?
Yes, I'm pretty sure its a mod to possibly lower noise. Absolutely optional and experimental I think. I don't think Nelson used it in commercial versions but I certainly recall him offering it as a potential upgrade. He suggested starting with 1uf and possibly more. The higher the value the more turn on thump you may get.
regards
Crazy Yankee.
Old 1st November 2005, 04:26 PM   #794
troystg's Avatar
Ok I bought some 2% Metal film resistors @ Fry's yesterday for the output boards.
They were out of 220 Ohm, so I bought 200 and 470.
Which should I use? The 200 or 2(two) parallel 470's?
How critical is that 20Ohms? It is 20% of the value... I can either go 20 down or 15 up from the spec'ed 221....
Troy
Old 14th November 2005, 08:23 PM   #795
Tarasque's Avatar
The 220 Ohm resistors are not really critical. The 220 Ohm will get you enough margin to prevent oscillation while maintining enough speed.
Go higher, say 470 - 820 Ohm and have more safety with less speed.
Go lower, say 50 - 100 Ohm and enjoy high speed with high risk of oscillations.
(I actually have achieved 22 amps at 11Mhz...and winded up with super heated FET's)
Old 14th November 2005, 09:31 PM   #796
troystg's Avatar
Thanks Tarasque for the reply. I did error on the side of caution and went the parallel 470 route so I have 235 Ohms in each position. Now I just need to order the caps...
22 amps @ 11Mhz!!! Doing radio transmissions? Applied for your broadcasterís license?
Troy
Old 18th November 2005, 02:08 PM   #797
Any need to match ouput devices on the mini?
Old 18th November 2005, 02:17 PM   #798
Hanzwillem's Avatar
Not really, since there is only one gain FET per channel, but if you're a purist perhaps you would like left and right to be exactly the same
They must have been holy chips or something - Pedro
Old 24th November 2005, 01:27 PM   #799
I'm missing a couple items on amp board... nothing serious. In the position of R12, a 750 ohm, would a substitute of 820 (in the kit) or a 680 (on the bench) be the better choice?
Old 27th December 2005, 12:13 AM   #800
Default Mini & 30 combo
So here's my project...
It's a combo Mini & 30... four channel for bi-amping some line arrays...
I am waiting for the second transformer...
mini-aleph versus aleph-3 rmgvs Pass Labs 7 4th February 2010 03:18 PM
Mini Aleph Board & Aleph 2 Parts List gpsmithii Pass Labs 3 16th January 2010 03:58 AM
Aleph Mini / Aleph 3 PCB ready (?) croccodillo Pass Labs 5 27th July 2009 01:51 PM
Difference between Aleph J and Aleph J Mini ppmmcc Pass Labs 5 17th May 2008 06:10 PM
WTB: Aleph-mini PCBs and transistor set for Aleph 30 needtubes Swap Meet 4 6th November 2005 06:29 PM
Copyright ©1999-2017 diyAudio
