New Aleph Mini PCB GB - Page 42 - diyAudio
Old 5th April 2005, 11:23 AM   #411
BrianGT is offline BrianGT  United States
diyAudio Moderator Emeritus
BrianGT's Avatar
Send a message via AIM to BrianGT
I also did a 6 capacitor version of the revised board, but I was concerned that it would be too large for some chassis designs.
Brian
Old 5th April 2005, 12:03 PM   #412
BrianGT's Avatar
Originally posted by Jean
I like this new revision of the power supply board also. My only suggestions would be, maybe allow the board to use to220 style resistors with same heatsinks as the diodes ? maybe 2 per rail ?
I could easily fit room for 1 heatsinked to-220 resistor per rail. Caddock MP930 resistors are rated at 30w when heatsinked, which is twice the rating than the 5 - 3w resistors in parallel.
I would still stick to 5 - 3w resistors, as I feel more comfortable having 5 components in parallel.
Brian
Old 5th April 2005, 12:18 PM   #413
BrianGT's Avatar
Originally posted by Coulomb
I like the new board Brian, the larger caps are a nice option. The problem is for people who perscribe to the theory that smaller caps have less ESR and react to current fluctuations faster then large caps, they can no only put four caps on the board.
Is there a way you could put both footprints on the same board, 6 smaller caps or 4 larger ones? That way the user can populate the boards to his or her liking. If you juggle the real estate with enough finesse I am sure you could come up with some workable gemoetry.
Anthony
The larger capacitors have a lower individual ESR than the smaller capacitors, so there is no advantage in terms of ESR using 6 TS-UP capacitors vs. 4 T-HA capacitors.
For the caps that I have here now:
10,000uF 50v TS-UP 35mm x 30mm
ESR @ 120hz = 0.036 ESR @ 20khz = 0.027
For an equivilant capacitance bank:
15,000uF 50v T-HA 35mm x 50mm
ESR @ 120hz = 0.022 ESR @ 20khz = 0.018
Run the numbers for the capacitor bank and you will see that the larger caps will allow for the same, if not lower ESR, since ESR is also a function of the capacitor size.
If you want to go for a significantly lower ESR bank, try paralleling a bunch of smaller Panasonic FC capacitors, but I feel that this is beyond the scope of this project.
Panasonic T-HA datasheet:
http://www.panasonic.com/industrial/...series_dne.pdf
Panasonic TS-UP datasheet:
Brian
Old 5th April 2005, 12:45 PM   #414
I like the board above. I have used 120,000 mfd Panasonic T-HA caps in the mini that I use at home with fantastic results. On this version of the board one could have 360,000 mfd per rail for a mini running +\- 15 volts. Now thats alot of total capacitance which will also have very low ESR!! I can vouch that just 1 pair of these caps in a mini sounds amazingly good, now thing three pair..... .
Mark
Old 5th April 2005, 12:47 PM   #415
Readsy to pay, I went looking to check if prices are USD or $C, but couldnít find it.
Itís also not where the prices are - on the Wiki(?)
What is it??
Old 5th April 2005, 12:48 PM   #416
BrianGT's Avatar
What is it??
All prices are in USD for the PCB orders, which you can place on the website:
http://www.chipamp.com/aleph
Brian
Old 5th April 2005, 12:50 PM   #417
BrianGT's Avatar
Alright, I have placed both layouts on my webpage:
Version 1a:
http://chipamp.com/diyaudio/ps1a.gif
6 capacitors, board size = 3.5" x 8"
Version 1b:
http://chipamp.com/diyaudio/ps1b.gif
4 capacitors, board size = 3.5" x 6.5"
The capacitor footprints on both layouts accept either the smaller 2-pin or larger 4-pin snap-in capacitors.
Both layouts will be modified to use a TO-220 CRC resistor:
http://www.diyaudio.com/forums/showt...674#post612674
The only real issue with these boards is the extra 1.5" size of the 6 capacitor version.
I placed a poll on my website here:
http://www.briangt.com/gallery/PS-poll
Based on the feedback that I get, I will place the order.
I did some chassis measurements, and 3.5" x 8" works fine in my chassis.
Brian
Old 5th April 2005, 12:51 PM   #418
Thanks Brian, I've paid you, and now want to pay Jason for the parts
Cheers
Old 5th April 2005, 12:52 PM   #419
troystg is offline troystg  United States
troystg's Avatar
Brian-
My 2 cents...
Please add at least another 2 holes on the grnd plane on the output side.. Maybe even a hole big enough for a bolt/nut combo.
There is always something else that needs a good ground point.
Troy
Thinking positive doesn't make things better, it makes you a better person.
Old 5th April 2005, 12:53 PM   #420
BrianGT's Avatar
Originally posted by rabstg
Brian-
My 2 cents...
I will do this for the board. I had multiple output pads on the older board, but removed them during the redesign and forgot to add them again.
Brian
mini-aleph versus aleph-3 rmgvs Pass Labs 7 4th February 2010 03:18 PM
Mini Aleph Board & Aleph 2 Parts List gpsmithii Pass Labs 3 16th January 2010 03:58 AM
Aleph Mini / Aleph 3 PCB ready (?) croccodillo Pass Labs 5 27th July 2009 01:51 PM
Difference between Aleph J and Aleph J Mini ppmmcc Pass Labs 5 17th May 2008 06:10 PM
WTB: Aleph-mini PCBs and transistor set for Aleph 30 needtubes Swap Meet 4 6th November 2005 06:29 PM
Copyright ©1999-2017 diyAudio
