New Aleph Mini PCB GB - Page 141 - diyAudio
Old 15th February 2011, 05:33 PM   #1401
BobEllis's Avatar
The ZTX parts have slightly different Vbe, so the protection point and bias setting would be slightly different. Your call.
One of the original Aleph clones used a 100K trimpot in the R13 position. You can also use a trimpot for R12 to experiment with AC current gain. I'd also have pads for fixed resistors once you determine your favorite values.
R17 should be less than R21. The actual values aren't too critical, but you don't want to see more than ~.3V across R17 in normal operation. R17 and R21 form a voltage divider. If your bias is 1A, you'll see ~.47 V across R27. A lot of interdependence. You can leave out R17, R21 and Q4. It just means that you don't have short circuit protection.
I'd avoid R6. Just match your input devices well. You might want to play around with different devices in the front end - in one of the shootouts a few years ago the ZVP3310 was preferred to the IRF9610 positions. But that was before people started playing with 2SJ74s.
The Jfets and ZVN3310 share the same lead order, but opposite body orientation. The lead order and spacing for the IRF9610 is different. If you want to allow for both you'll need two sets of pads.
Old 15th February 2011, 05:57 PM   #1402
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
I use a trimpot for offset and bias control.
Salas Boards GB 2017#1 ON ORDER | GB 2017 #2 Click Here to Sign Up! | Hot-Rod DCB1 boards and kits In Stock, PM | M2C Boards On ORDER
Old 17th February 2011, 02:45 PM   #1403
When iīm going to drive the amp unbalanced all time, without thinking on driving it balanced, can R2, R9, R10, C1, Z3, Z4 be omitted?
Old 17th February 2011, 06:32 PM   #1404
RIP
If you would do a search for the original Mini-A thread all your questions will be answered in the very first post.
Best, Bill
Old 17th February 2011, 07:14 PM   #1405
Thanks for the hint, Bill
One last question here: Can i build this amp linke itīs shown in the original Mini-A thread with the values of the parts in briangtīs schematic?
Old 17th February 2011, 07:38 PM   #1406
BobEllis's Avatar
What does the suggestion for liberal use of trim pots and the large variety of values used in the same basic circuit in the Aleph series tell you? It shouldn't say that all parts values are critical and the circuit won't work with any changes. There are a couple that are interdependent, but the circuit isn't hard to figure out what each change will do for you.
Old 17th February 2011, 09:05 PM   #1407
RIP
As Bob is saying, you can change damned near anything as long as you understand what sets the bias current, the overall gain, the AC current gain, and what maintains the near zero output offset. The Zen articles are the best source for study.
Have fun, Bill
Old 4th December 2012, 11:52 PM   #1408
Default xls to pdf for Aleph-5
Hello everyone, Could someone please post the BOM converted to a pdf for building a Aleph-5 with the chipamp.com black pcb's ? Thank's any help would be greatly appreciated !
Old 5th December 2012, 12:13 AM   #1409
wow. thats an old tread.
Bill, R.I.P.
Old 5th December 2012, 12:20 AM   #1410
MEGA_amp's Avatar
There is no BOM for an Aleph5 specifically, but you can certainly utilize those boards for the Aleph5, I built 4 or 5 with various voltage/bias configs. With those boards you get an Aleph with the bonus of the Aleph 30/60 input, which allowed for more gain when using unbalanced inputs. You'll need to dig around for the schematics. The front end of the Alephs are all virtually the same, it's the back end, voltages, bias which is where they differ. The Aleph 30 is essentially the same configuration as the Aleph 5, just slightly different input (noted above), less bias/voltage, and a few resistor changes.
mini-aleph versus aleph-3 rmgvs Pass Labs 7 4th February 2010 03:18 PM
Mini Aleph Board & Aleph 2 Parts List gpsmithii Pass Labs 3 16th January 2010 03:58 AM
Aleph Mini / Aleph 3 PCB ready (?) croccodillo Pass Labs 5 27th July 2009 01:51 PM
Difference between Aleph J and Aleph J Mini ppmmcc Pass Labs 5 17th May 2008 06:10 PM
WTB: Aleph-mini PCBs and transistor set for Aleph 30 needtubes Swap Meet 4 6th November 2005 06:29 PM
Copyright Đ1999-2017 diyAudio
