New Aleph Mini PCB GB - Page 129 - diyAudio
Old 30th January 2010, 06:18 AM   #1281
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
Originally Posted by cjkpkg View Post
I went with 3.3K bleeders for R1 and R2...tonight I hooked up the PSU to my xformer on the test bench in the C-C-C setup. It is a 200VA 12VAC toroid. I measured 17.2VDC on the PSU outputs.
I have placed an order for 10 .47ohm 3W resistors with some other misc stuff I needed...The voltage drop obviously will be negligible.
My HiFi2000 chassis shipped today so it should arrive in the next week or 2...cant wait to get it all assembled.
You will like the crc
Old 30th January 2010, 02:11 PM   #1282
udailey is offline udailey  United States
HiFi2000..... You lucky dog!
purchase LDRs anytime Also try my Resistor Replacers or LDR based Input Selector Email me. diyldr@gmail.com
Old 30th January 2010, 05:01 PM   #1283
Banned
Order one then
As soon as i start making a little bit of $$ ill be ordering 2
Old 30th January 2010, 08:49 PM   #1284
cjkpkg is offline cjkpkg  United States
OK...I hooked everything up for a quick bench test...no inputs...
On both boards, only one of the mosfets(Q6) have voltage? normal?
Also, even the ones that have voltage are not warm at all...mounted temporarily on a sheet of aluminum...
Can someone give some guidance as to what voltages ought to be at particular critical points? I could probably stumble through but I'm sure someone has been here before...
Thanks in advance...
Old 30th January 2010, 08:57 PM   #1285
Banned
can you post pictures ?
Do you have all 3 power wires connected ? Positive negitive and gnd ?
jase
Old 31st January 2010, 06:53 PM   #1286
Yes...all power and earth ground connected from the wall to PSU board and to ch ground on the amp board.
Here are some voltage observations...
Q1: 9.2 -17.3 3.2
Q2: 0 -15.6 3.2
Q3: 13.2 3.2 16.35
Q4: -17.3 -17.3 -15.59
Q5: 17.1 17.2 17.2
Q6: -17.3 17.1 -15.6
Q7: 17.2 17.3 17.1
I hooked up an input and a small test speaker and there is no sound coming out...
I also took readings at all resistor terminals so I have those if it helps...
Carl
Old 31st January 2010, 08:36 PM   #1287
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
I dont think your source resistors are working,
What is the voltage across both sides of the resistors on Q6 and Q7, or r27 and r28.
So put volmeter positive on one side of the resistor, the other on the other side.
Should be ~.5v or 500mv.
Salas Boards GB 2017#1 Click Here to Sign Up! | Hot-Rod DCB1 boards and kits In Stock, PM | M2C Boards Out of stock
Old 31st January 2010, 08:41 PM   #1288
Banned
Q1: 9.2 -17.3 3.2
Q2: 0 -15.6 3.2
Q3: 13.2 3.2 16.35
Q5: 17.1 17.2 17.2
Q7: 17.2 17.3 17.1
Carl
Post pictures ? Don't forget to short the input side of the balanced to gnd.
Old 1st February 2010, 11:47 AM   #1289
R27: 17.29 / 17.29
R28: 17.06 / 17.06
I'll post pics later today...couldn't find my camera until late last night...
Old 1st February 2010, 12:12 PM   #1290
***insert facepalm***
R13 - I ordered 47.5 ohm instead of 47.5k ohm...rookie...
who knows what else I fried as a result...
mini-aleph versus aleph-3 rmgvs Pass Labs 7 4th February 2010 03:18 PM
Mini Aleph Board & Aleph 2 Parts List gpsmithii Pass Labs 3 16th January 2010 03:58 AM
Aleph Mini / Aleph 3 PCB ready (?) croccodillo Pass Labs 5 27th July 2009 01:51 PM
Difference between Aleph J and Aleph J Mini ppmmcc Pass Labs 5 17th May 2008 06:10 PM
WTB: Aleph-mini PCBs and transistor set for Aleph 30 needtubes Swap Meet 4 6th November 2005 06:29 PM
Copyright ©1999-2017 diyAudio
