New Aleph Mini PCB GB
Old 7th May 2005, 02:31 PM   #581
eugenio is offline eugenio  Italy
Now I can start....
what do you think about my heatsinks and part???
2 x 0.5KW transformers
2x68000uF 40V ITELCOND caps or 12x10000uF 100V ROE caps
.6W 1% MF PHILIPS resistors
5W 5% MF RESISTA resistors
220uF 35V ELNA CERAFINE caps
IR irf9610
FARICHILD irfp240B
VHD and SOLEN cables
WBT connectors
but I have a question....
can I use this heatsink for an ALEPH 5 ( 1 for channel ) ???
tnx Brian!!!!
I love music
Old 7th May 2005, 05:47 PM   #582
dhole is offline dhole  United Kingdom
dhole's Avatar
Im on the way with my aleph 5 hope my sinks are big enough...
I am a little confused ,in that I have a 28-28 toroid and I get 37.7 regulated per rail unloaded. I dont have crc etc I just wanted to be as close to the original A5. I will try to get hold of a variac to bring the amp up on , but should the circuit be able to cope?...
dave
Old 7th May 2005, 05:58 PM   #583
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
I like those Potted Transformers. Id like to get my hands on 2 of them.
Old 7th May 2005, 06:04 PM   #584
...dhole.... add the 75°C thermal switch on the heatsink for safety...
like original Aleph....
if heatsink is small the amplifier is safe!!!
good job friend...
sorry for my bad english
I love music
Old 7th May 2005, 06:13 PM   #585
Coulomb is offline Coulomb  England
Coulomb's Avatar
dave
That rail should drop to about 33VDC under load, it depends on the regulation factor of the transformer.
Anthony
I like to stay current!
Old 8th May 2005, 12:49 PM   #586
dhole's Avatar
Thanks for the advice. I am going to put the finishing touches to my amp today.....
Can anyone recommend a 75 degree temp switch?...
dave
Old 8th May 2005, 02:47 PM   #587
dhole's Avatar
My unbalanced input on my aleph 5... should I use UIN and GND ? UIN being HOt and Gnd the sheild ?
regards
dave
Old 8th May 2005, 03:20 PM   #588
.....balanced input is also used to change voltage gain.....shorting -IN and GND....
Nelson says:
"T1 is a thermostatic switch rated at 75 degrees Centigrade. It is mounted to the rear heat sink. ....
....The amplifier is designed so that the heat sinks will operate approximately 25 degrees C above ambient, for a typical temperature of 50 degrees C.
Temperature protection occurs at 75 degrees C....."
I love music
Old 8th May 2005, 03:31 PM   #589
Stones is offline Stones  United States
Stones's Avatar
dave
Farnell
3775586
Old 8th May 2005, 03:54 PM   #590
....this is digikey catalog...
http://dkc3.digikey.com/PDF/T052/1179.pdf
I love music
New Aleph Mini PCB GBHide this!Advertise here!
mini-aleph versus aleph-3 rmgvs Pass Labs 7 4th February 2010 04:18 PM
Mini Aleph Board & Aleph 2 Parts List gpsmithii Pass Labs 3 16th January 2010 04:58 AM
Aleph Mini / Aleph 3 PCB ready (?) croccodillo Pass Labs 5 27th July 2009 02:51 PM
Difference between Aleph J and Aleph J Mini ppmmcc Pass Labs 5 17th May 2008 07:10 PM
WTB: Aleph-mini PCBs and transistor set for Aleph 30 needtubes Swap Meet 4 6th November 2005 07:29 PM
Copyright ©1999-2017 diyAudio
