New Aleph Mini PCB GB New Aleph Mini PCB GB - Page 5 - diyAudio
Old 26th February 2005, 01:26 PM   #41
Ruben is offline Ruben  Switzerland
Balanced inputs would be great!
Ruben Begert.
Old 28th February 2005, 01:49 AM   #42
BrianGT is offline BrianGT  United States
diyAudio Moderator Emeritus
BrianGT's Avatar
Send a message via AIM to BrianGT
Well, you asked for it... I made a new version that accepts balanced inputs and uses the same input circuit as the Aleph 30/60.
The board is 0.1" wider
I can't take screenshots here very well, so I created a pdf from the gerber files with Pentalogix Viewmate and attached the pdf. The pdf shows both layers, green = bottom layer, red = top layer
Any comments?
Brian
Old 28th February 2005, 01:50 AM   #43
BrianGT's Avatar
Seperate pages for top and bottom layer:
Brian
Old 28th February 2005, 02:28 AM   #44
kilowattski is offline kilowattski  United States
kilowattski's Avatar
Brian,
Thought you were away this weekend. Must have brought your laptop.
Kilowattski
Old 28th February 2005, 02:33 AM   #45
BrianGT's Avatar
Originally posted by kilowattski
Brian,
Exactly.. I am still away now in Pennsylvania, but I brought my laptop, and had a chance to use the net at my uncle's house.
Here is another picture of the layout, taken the same way as the previous shots:
Brian
Old 28th February 2005, 02:46 AM   #46
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
I cant remember but can they be run in RCA mode and or balanced ?
Old 28th February 2005, 02:50 AM   #47
BrianGT's Avatar
Yes, for unbalanced, the input goes into the +IN. View the schematic here:
http://www.passlabs.com/downloads/ol...t/a30manr0.pdf
or
http://www.passlabs.com/downloads/ol...t/a60manr0.pdf
The resistor numbers are not all the same, but the circuitry is the same.
Brian
Old 28th February 2005, 04:28 PM   #48
tiroth is offline tiroth  United States
Balanced version.
Old 1st March 2005, 01:47 PM   #49
Billc is offline Billc
Bravo!!
Old 1st March 2005, 01:50 PM   #50
BrianGT's Avatar
Originally posted by Billc
Bravo!!
Thanks. Here is a pcb with output boards attached to it to form a pcb set:
The thicker pink lines indicate scoring, so the board can be broken apart. (as far as heat dissipation, they would have to be broken apart for larger powered amplifiers)
The resistors on the output boards are 2 - 2w resistors in parallel, which deviates from the single 3w resistors used in the production Aleph amps.
Brian
New Aleph Mini PCB GBHide this!Advertise here!
mini-aleph versus aleph-3 rmgvs Pass Labs 7 4th February 2010 03:18 PM
Mini Aleph Board & Aleph 2 Parts List gpsmithii Pass Labs 3 16th January 2010 03:58 AM
Aleph Mini / Aleph 3 PCB ready (?) croccodillo Pass Labs 5 27th July 2009 01:51 PM
Difference between Aleph J and Aleph J Mini ppmmcc Pass Labs 5 17th May 2008 06:10 PM
WTB: Aleph-mini PCBs and transistor set for Aleph 30 needtubes Swap Meet 4 6th November 2005 06:29 PM
Copyright ©1999-2017 diyAudio
