New Aleph Mini PCB GB
Old 20th March 2005, 07:28 AM   #211
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
2 Weeks later and here is my regulator board.
Old 20th March 2005, 07:49 AM   #212
pinkmouse is offline pinkmouse  Europe
pinkmouse's Avatar
How much current will you be pulling from this?
The tracks seem very thin for a PSU , and for best cooling, spread the Qs out along the full width of the board.
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 20th March 2005, 07:58 AM   #213
Banned
Im working on spreading the q's out right now. And making the track's a bit bigger..
Old 20th March 2005, 09:48 AM   #214
kilowattski is offline kilowattski  United States
kilowattski's Avatar
Make your board design with provisions for PCB terminal blocks for input and output as Brian did. Why not put the bridge rectifiers on the board with enough space for large PCB heatsinks for them so external wiring would be minimal. It would also be interesting to see the schematic you are using and what values you plan on using for the Mini Aleph.
Kilowattski
Old 20th March 2005, 12:38 PM   #215
seve is offline seve
Output boards!
I would like to know how well 3W panasonic resistors will fit the ouput board. I know it's specified for 2W resistors, but I would like to use the boards with my upcoming Aleph-X and already have some 3W panasonic resistors I want to use. Also can the output board handle a Aleph-X biased around 6-8 amp? If not I will have to change me amount in the Wiki.
Martin
Old 20th March 2005, 01:34 PM   #216
BrianGT is offline BrianGT  United States
diyAudio Moderator Emeritus
BrianGT's Avatar
Send a message via AIM to BrianGT
Originally posted by jleaman
I hope brian puts on cut lines and that the pcb place makes it easy to snap them : O ) NOt may of us have a band saw. But a exacto Knofe worked for tbe Gain clone kit's.
The boards will have scoring, as with my Chipamp boards, which will allow them to be easily cut apart. They were not meant to be cut apart with a hacksaw, but for the prototypes, it wasn't possible to get scoring.
Brian
Old 20th March 2005, 01:38 PM   #217
BrianGT's Avatar
Originally posted by Mark A. Gulbrandsen
I just posted a fresh batch of photos on Brian's gallery.
One thing for sure... this is one tight little board! If you use 1/4 watt 1% resistors they will have to be stood on end. I don't really mind this practice at all myself. Over the years I've seen MANY pieces of pro gear from Dolby and others that have been done just this way. What I did do was to alternate the positions of the bodys of them so that should they get bent over there will be less likelyhood of them touching. All in all I don't have any problems with doing it this way.
One more thing we all need to get straight here and perhaps develop is a resistor value chart for this "universal board" showing the values of the resistors used in the different Alephs. Since this test circuit is going to be a Mini-A I am goig to make R-12, 14, and 16 750 ohms. R-13 will be 47.5K, and R-17 at 392. I will leave the feedack values just the way they since we are sticking with the balanced input. I will leave out R-6 for now since my input fets are very well matched, but we can all go back and explore tunning that value once this board is up and running. I will need advice from Brian and others on this matter so those that are qualified to chime in please do so. I would like to see a chart developed to refer to for the correct values for those positions depending on what model Aleph you want to build. It will make it alot less confusing for those that are new to this project.
Thanks!
Mark
As for the resistors, the layout is intended for compact 0.5w metal film resistors which have a body length of 0.126", working well with the 0.2" spacing. I will post a parts list soon for the project..
Here is a picture of the metal film resistors, used in my mic preamp prototype:
http://chipamp.com/diyaudio/micpre-assembly-highres.jpg
As for the resistor values, we can work up a chart of values for the circuit. R6 isn't needed, but I included it on the layout for optimal input fet matching, as Nelson did on the A30.
Brian
Old 20th March 2005, 02:59 PM   #218
BrianGT's Avatar
Here is an initial parts list for building the mini Aleph or Aleph 30 with these boards:
Brian
Old 20th March 2005, 03:46 PM   #219
BrianGT's Avatar
looks like I forgot the link:
http://chipamp.com/diyaudio/miniALEPH-parts_list.xls
Brian
Old 20th March 2005, 05:52 PM   #220
Mark A. Gulbrandsen is offline Mark A. Gulbrandsen
I just posted a few more pictures in Brian's gallery. All I need are three 750 ohm ressitors to complete this channel and we can test it. Because everything in the State of Utah is closed on Sunday this will have to wait till tommrrow...... fortunately I only work a mile from Ra-Elco! Check back tommrrow night for more pictures and hopefully a working Mini-A channel.
Mark
New Aleph Mini PCB GBHide this!Advertise here!
mini-aleph versus aleph-3 rmgvs Pass Labs 7 4th February 2010 03:18 PM
Mini Aleph Board & Aleph 2 Parts List gpsmithii Pass Labs 3 16th January 2010 03:58 AM
Aleph Mini / Aleph 3 PCB ready (?) croccodillo Pass Labs 5 27th July 2009 01:51 PM
Difference between Aleph J and Aleph J Mini ppmmcc Pass Labs 5 17th May 2008 06:10 PM
WTB: Aleph-mini PCBs and transistor set for Aleph 30 needtubes Swap Meet 4 6th November 2005 06:29 PM
Copyright ©1999-2017 diyAudio
