New Aleph Mini PCB GB
Old 11th March 2005, 12:20 AM   #101
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
Originally posted by BrianGT
There will be 2 pcb sets,
- amplifier pcb set: 2 amplifier boards and 4 output boards
- power supply set: 1 power supply board and 1 soft start board
I am revising the amplfier board set currently, and will post a new picture when I finish. I should be ready to order prototype pcbs next week for this. As for the power supply pcb set, I am working to put together a circuit for prototyping the soft start / momentary switch pcb. If people are constrained on time, I could remove the momentary switch board (based on this design: http://maxhawk.bravepages.com/projec...non/index.html ) and only make the soft start board be a board with an AC recepticle, AC fuse and thermistors for handling inrush current.
My goal is to make each pcb set around $20 each (depends on interest and production cost), and make them with a blue soldermask and 3 to 4oz copper for extra current handling on the traces.
There are no dates currently set for this project, but it is not on the back burner and is my primary focus when it comes to new projects.
Brian
i'm Wondering do we really need this inrush current thing ?
Old 11th March 2005, 03:10 AM   #102
kilowattski is offline kilowattski  United States
kilowattski's Avatar
You won't need it if you fancy resetting your circuit breaker every time you turn your amplifier on.
Kilowattski
Old 11th March 2005, 03:24 AM   #103
Banned
I bet i will have to do this when my aleph 2's are done. 2 x 1kva toroidal with 300thousand mf's per rail so that 4 x : O ) yeah il be ressting the breaker : O )
Old 11th March 2005, 06:20 AM   #104
BrianGT is offline BrianGT  United States
diyAudio Moderator Emeritus
BrianGT's Avatar
Send a message via AIM to BrianGT
I can easily make the inrush current board with the a pcb mount AC recepticle, AC fuse and the thermistors (labelling for selection 120/240 wiring with the transformer).
The issue at hand is currently the creation of a board that would allow for the use of a momentary switch with a relay and flipflops for turning off an on the amp. If this is not needed, then the boards are almost ready to be ordered for prototypes.
Brian
Old 11th March 2005, 06:23 AM   #105
steenoe is offline steenoe  Denmark
steenoe's Avatar
No need to hurry. Better is it, to have a complete and perfected project. Great ideas has come up so far and I would like to see them all implemented.
Steen.
Old 11th March 2005, 07:15 AM   #106
BrianGT's Avatar
Here is the revised amp board:
I placed the old version here:
http://chipamp.com/diyaudio/miniA-with_output-old.gif
Changes:
- added extra holes on output boards for paralleling the device boards
- thickened the high current traces
Let me know if you have any comments,
Brian
Old 11th March 2005, 07:28 AM   #107
steenoe's Avatar
Brian, are the board still 2,9"x2"? Or better still could you post the dimensions of each board, main and output? (inch or mm)
Steen.
Old 11th March 2005, 12:02 PM   #108
BrianGT's Avatar
Steen.
You should be able to see them from the above drawing, but here they are separately:
amp board: 2.2"x3.5"
output board: 1" x 3.5"
power supply board currently is 3.4" x 6.4"
Brian
Old 11th March 2005, 03:52 PM   #109
troystg is offline troystg  United States
troystg's Avatar
Brian
Hey Brian-
No hurry, I just plan out my projects so I can forecast funding and time needs.
I try not to have more than 3 projects going at once so at least ONE has a chance to be completed.
I think your current plan for an "all inclusive" pwr supply PCB is best.
And thanks in advance, I know it will be as good a PCB as your LM3875/86. Of which I own both and enjoy.
Troy
Old 11th March 2005, 04:04 PM   #110
steenoe's Avatar
I had gone blind on those mil digits Now I see them.
Thanks. It all looks really good so far
Steen.
New Aleph Mini PCB GBHide this!Advertise here!
mini-aleph versus aleph-3 rmgvs Pass Labs 7 4th February 2010 04:18 PM
Mini Aleph Board & Aleph 2 Parts List gpsmithii Pass Labs 3 16th January 2010 04:58 AM
Aleph Mini / Aleph 3 PCB ready (?) croccodillo Pass Labs 5 27th July 2009 02:51 PM
Difference between Aleph J and Aleph J Mini ppmmcc Pass Labs 5 17th May 2008 07:10 PM
WTB: Aleph-mini PCBs and transistor set for Aleph 30 needtubes Swap Meet 4 6th November 2005 07:29 PM
