New Aleph Mini PCB GB
Old 5th May 2007, 01:25 AM   #1021
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
1) you would never even know if the cap was in backwards or not, it is extremely hard to know the difference in sound.
2) run 2/3 shielded wires from your input right to the board, depending if you are running balanced or line level. then run your 3 wires for your power right to the psu board. twisting / braiding really helps.
3) i can post pictures later on when i arrive hoe if you wish. I run 4 of these amps ( smd ) ones tho.
Jase
Old 5th May 2007, 02:00 AM   #1022
hayenc is offline hayenc  United States
hayenc's Avatar
Send a message via Yahoo to hayenc
I checked the silkscreen on the old and new boards I have. C1 is fixed on the new boards.
Old 6th May 2007, 01:24 AM   #1023
Banned
Very good to know, thanks.
J'
Old 18th May 2007, 07:35 AM   #1024
gil-garcia is offline gil-garcia  France
Hello,
j'am,just starting to realize a 5 channel Mini A with PCB and PSU from chipamp. It is the most beautifull pcb j have never seen .
One small problem, impossible to find in europe the small resistances.
The project is :
2 transformers 300VA, 2x15V (one for front two channel and one for the others tree channel)
4 PSU board (2 for the front channel, 2 for the 3 others channel)
As j am a beginner and as j have read a lot of thread with the impression that everybody do not speak always about the same schématic and references of resistors j am a bit lost.
Can you help me
Accordind to the part list from the site :
R6 optional, for closer matching of Q1 and Q2
R12 : 750 initial value, could be optimized for expected power/load conditions
R13 : 47.5K initial value, could be optimized for expected power/load conditions
R17 : 100 initial value, could be optimized for expected power/load conditions
j would like to have a bias about 1,3 with something like 18-20V with my 2X15V transformer.
Could you tell me the values for R6, R12, R13 and R17. Do j have others componants to change the value.
in this configuration, could you tell me what would be the best configuration in order to connect the psu board, which value for the res of the psu (pi filter), what kind of condensator and value at the end of the psu. If it is necessary, j have others psu boards in advance.
Thanks a lot and excuse me for my poor english, j hope it is clear?
Old 16th April 2008, 10:42 PM   #1025
Elkaid is offline Elkaid  Canada
Elkaid's Avatar
Send a message via MSN to Elkaid
Question Excel Spreadsheet
Hello everyone,
I'm trying to get my hand on the excel spreadsheet found on Brian's website but it seems down along www.chipamp.com.
If anyone has it near, it would be very appreciated
Thank you !
Old 17th April 2008, 04:57 AM   #1026
sandstorm33 is offline sandstorm33  United States
sandstorm33's Avatar
Default Re: Excel Spreadsheet
Originally posted by Elkaid
Hello everyone,
Thank you !
EMAIL ME!
Old 17th April 2008, 01:33 PM   #1027
ssmith is offline ssmith  Kenya
here
Old 17th April 2008, 07:28 PM   #1028
Elkaid's Avatar
Thanks a lot to both of you guys
Have a nice day !
Old 7th May 2008, 12:16 PM   #1029
BrianGT is offline BrianGT  United States
diyAudio Moderator Emeritus
BrianGT's Avatar
Send a message via AIM to BrianGT
FYI, I have more of black Aleph pcb sets, and put them back up on the website for $9 a pcb set.
(set still includes 2 amp boards and 4 output device boards)
Here is the parts list that I generated back in 05 when the first run of boards were made:
http://www.chipamp.com/diyaudio/mini...parts_list.xls
Let me know if you spot any issues, and I can correct it. I built a set of MiniA amps with the list, and had no issues.
Here is a newer one that I found that has a bit more detail:
http://www.chipamp.com/diyaudio/mini-A.xls
Brian
Old 7th May 2008, 01:22 PM   #1030
guitvinny is offline guitvinny  Canada
guitvinny's Avatar
Good to hear that !
Just got 3 ! Thank a lot !
New Aleph Mini PCB GBHide this!Advertise here!
mini-aleph versus aleph-3 rmgvs Pass Labs 7 4th February 2010 03:18 PM
Mini Aleph Board & Aleph 2 Parts List gpsmithii Pass Labs 3 16th January 2010 03:58 AM
Aleph Mini / Aleph 3 PCB ready (?) croccodillo Pass Labs 5 27th July 2009 01:51 PM
Difference between Aleph J and Aleph J Mini ppmmcc Pass Labs 5 17th May 2008 06:10 PM
WTB: Aleph-mini PCBs and transistor set for Aleph 30 needtubes Swap Meet 4 6th November 2005 06:29 PM
Copyright ©1999-2017 diyAudio
