Old 21st February 2005, 08:54 PM   #1
Default 6x ladder attenuator on active system
I want to use a six-channel ladder attenuator on my active system. The attenuator is between active filter (opamp output) and different Aleph amps. The problem is that I use an Aleph5 for low freq. and two Aleph 3's for mid and high freq. Trouble is that the input impedance of the 5 and 3 are not the same; 10k and 23k. This will affect my attenuator so that if I would use the same resistor for all freq's the attenuation will not be the same due to the parallel input impedance. Offcourse I could use and extra buffer stage between attenuator and Alephs but I dont like the extra opamp.
My question is; if I would use the standard calculations of a 'ladder attenuator with grounding resistor'
http://www.platenspeler.com/backgrou...#example_l12bn
can I 'see' the grounding resistor as being the input impedance and calculate the different resistors according the amp used so that I will get the same attenuation on all steps and all freq's???
Old 24th February 2005, 08:56 AM   #2
I have decided to put in the extra opamp because the problem will be to complex to solve with simple calculation. And it will be easier adaptable to other situations.
I am using the opa2134pa
any way to better them or easy replaced with better dip?
10K Ladder attenuator kit for sale. Tony D. Swap Meet 3 30th November 2005 09:55 PM
10k, true ladder switching attenuator. Peter Daniel Swap Meet 4 4th February 2004 02:29 PM
Ladder relay attenuator or so? Eccu Solid State 0 6th October 2003 11:00 AM
Page generated in 0.07687 seconds (74.35% PHP - 25.65% MySQL) with 10 queries
