hi
first for a good power follower you need a
ccs (constant courant source) not just
a source resistor
and the best driver is a tube driver with
very low zout 50 ohm in my case
www.loginnovation.com/jeapel
bye
a source resistor
bye
maybe more explication
a source follower with ccs is very good :
gain=1
low distorsion without feedback
good widthband
but the sound is very neutral and to get a good
amplifier you need to add some personality to
the sound
a good way is tube (triode not pentode) with
even harmonics
don t forget if you go with transfo you need a equivalent
low zout 100 ohm max. to drive your output follower
but for me sorry double follower= double neutral sound
bye
gain=1
good widthband
the sound
even harmonics
bye
This approach looks similar to this underDear Nelson and friends,
please see this attachment,does this topology works properly.anybody have experiance in this circuit.please have a look at this
renjish
http://www.diyaudio.com/forums/solid-state/48364-class-power-follower-2.html
and those from Tim Paravicini (M100A)
https://www.stereophile.com/solidpoweramps/earyoshino_m100a_monoblock_power_amplifier/index.html
PARAVICINI M100A Mono Power
N C A U D I O (Jean Hiraga)
http://www.diyaudio.com/forums/pass-labs/144105-o-h-schade-1938-meets-mosfet-2.html#post1942621 (post #20)
A lot depends on the quality of the transformer, especially when the gain
is going to be 10:1, and you want to have a low impedance driving the primary.
