Looks like Fairchild just came out with this. 200V, 19A. Input capacitance is only 65% of the IRPF240. Appears to have a much higher transconductance too.
I'm new at this, so I would appreciate someone looking at the datasheet link below and giving me your feedback. Would this thing work better in a SOZ than the 240? http://www.fairchildsemi.com/ds/FQ%2FFQA19N20C.pdf
NV&H |
#2 |
OK, I put in the link for the FQA19N20 instead of the FQB.
The FQA has slightly higher current capacity and the same transconductance as the 240 but with 65% of the input capacitance. The FQB seems similar except for the much higher transconductance. Sorry for the mixup. Comments?
NV&H |
#3 |
Did it Himself
Well, I've just studied the datasheet for the FQA in your link and it looks good. Will drop right in to replace IRFP240. The only issue could be in switching circuits as rise/fall and Ton/off times are longer for the Fairchild part, but everything else looks better.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#4 |
They sound good. The Vgs is a little higher than the IRFP 240.
Can't get a 6-32 screw through them.
MikeW |
| AD 846 replacement | Fasen | Digital Line Level | 18 | 16th July 2009 04:33 PM |
| W3-871 replacement | e_fortier | Full Range | 7 | 1st October 2008 03:06 AM |
| class A amp using IRPF240 or others | space2000 | Solid State | 1 | 12th June 2008 03:32 AM |
| irf 740 replacement | bob_v5 | Solid State | 6 | 10th December 2005 02:16 PM |
| OP amp replacement | mieze245 | Chip Amps | 0 | 19th September 2004 06:46 PM |
| Page generated in 0.07560 seconds (72.20% PHP - 27.80% MySQL) with 10 queries |
