#131 | |
ciao, Roberto Amato |
#132 |
I just finish and test my Soft Start Circuit, it works fine I want to drive the PS of my futur Zen4 and in this case I want to know what kind of fuse I may use in the SSC! I have some T4 fuse, it's that a good value or not? |
#133 | |
In my monoblock SoZ I use a slow-blow 750ma fuse. The inrush current is so much tamed by the soft-start, that the fuse rating needed is just slightly above the current sucked from the AC line. ciao, Roberto Amato |
#134 |
sorry "SSC" means Soft Start Circuit! For the fise you're right T4 is for Slow Blow 4A Thanks for your help |
#135 |
Banned
My F5 has two 10A fuses in the AC supplies from the transformers to the bridge rectifiers. Immediately after the fuses I have two 30A relays which, in the event of a fault being detected short the AC rails causing the fuses to rupture. OK the PSU capacitors are still charged and will discharge through the speakers but this takes seconds. No relay contacts are in the path of the DC supplies, nor are there any contacts in the speaker paths. It's BRUTE FORCE I know but it has absolutely NO effect on the sonic performance of the amp and does give a degree of protection to the speakers.
You might argue that the mains fuse would probably blow in the case of major amp failure. I've never had a problem. |
#136 |
Recently I have lost two Focal woofers due to a failing DC protection circuit. Plus, it wasn't the first time that this happend to me. Thus I always considered speaker protection as an important issue and have wondered why so many amps are buildt without it. In my mind a poor protection circuit is worse than no protection ciurcuit!
Now I am in the process of building F5's without any protection circuits at all. As I need new speakers too, I really hope (and expect) that the F5's will work better and safe..! Last edited by Tiroler; 4th October 2010 at 08:49 PM. |
#137 | |
Thanks Pandu |
#138 |
My experience says that the F5 is very reliable. Now I think that is a pity that I made my F5's without DC-protection. And there is no room left to put such a circuit into the cramped F5's now. A good protection circuit probably needs more board surface than the amp itself... When I used the BoSoZ I felt pretty safe. Now I have the fantastic UGS preamp and my whole system is DC-coupled. That is not exactly without risk.
Therefore my next power amps must have an adequate protection. I think it should sit at the output and must disconnect the speaker or short the supply rails really fast. The electrolytics should not be allowed to discharge through the speaker. |
#139 |
Some of Apex protection circuits use the power of the fault condition to operate the protection. They could be located on, or in the speaker.
regards Andrew T. |
#140 |
If someone wants to play with Velleman K4700 speaker protection:
VellemanK4700 PCB and all other info is there...
Nothing to see here... |
| Looking for condenser microphone amplifier circuits | pebo | Solid State | 3 | 3rd September 2008 11:00 PM |
| protection diodes in LM317 circuits | jarthel | Parts | 2 | 14th September 2006 10:28 PM |
| speaker protection (OR) overload protection | myanmar | Solid State | 7 | 13th July 2006 08:21 AM |
| amplifier circuits | madan | Solid State | 27 | 23rd November 2005 11:08 AM |
| Discrete protection circuits | metal | Solid State | 6 | 24th February 2004 02:05 PM |
| Page generated in 0.11898 seconds (81.04% PHP - 18.96% MySQL) with 11 queries |
