Help me build a powersupply!
I want build an excellent powersupply for the pearl I'm building, but would appreciate some tips, or post about your custom powersupply. Thanks, Matt |
#2 |
Michele |
#3 |
Matt,
I built the Pearl almost two years ago. Since it was my first real DIY project, I built it exactly as Wayne described it in the article. The Pearl is a fine-sounding phono stage without any mods. I don't think you'll be disappointed building it "stock". If I were doing it over, I might try using soft-recovery diodes for AC recification and some film bypass caps for the PS electros, just because... Ren |
#4 |
Sounds good, I will build the stock psu.
If I install the power supply into a shielded metal case, is it OK to install it into the same chassis? Matt |
#5 |
Short answer: I don't really know.
Wayne recommended putting the PS in a separate chassis and I did that. However, I've never noticed any noise increase when I put the PS chassis right next to the preamp chassis. Ren |
#6 |
It's the same for me. Two metal chasses one on the other,but no problems. The sound ir really natural.
Ciao
Michele |
#7 | |
I also am very happy with my Pearl. It has a dual 30v, 50 watt Plitron transformer, schottky bridges, 10K ufd caps, and a pair of 4 mH 2 amp chokes. This is external from the main phono board. I really think that is better than one boxing the unit. A power transformer can really radiate a field even through a metal housing. The current draw on the Pearl is very small, 50 ma or so per channel. I really like chokes in the power supplies of class A circuits. George |
| Pearl phono with 24V battery supply | koli | Pass Labs | 1 | 9th August 2007 05:03 AM |
| Pearl Phono power supply | Gregorio | Pass Labs | 1 | 13th October 2004 06:12 PM |
| Power Supply for Pearl | dkimble | Pass Labs | 6 | 16th March 2004 05:57 PM |
| Pearl enclosure and power supply? | Boban | Pass Labs | 20 | 27th February 2003 03:43 PM |
| Beginner questions about Pearl power supply | Saurav | Pass Labs | 3 | 26th September 2002 04:18 PM |
| Page generated in 0.08814 seconds (75.39% PHP - 24.61% MySQL) with 11 queries |
